Opti rotor
Old May 8, 2009 | 12:00 AM
djbraxton's Avatar
djbraxton
Default Opti rotor
All,
Had to replace the opti on my GS. Installed the new part and the vette would not start. Checked all the wires and the cam index, everything was good. Vette still acted like in was trying to fire out of order.
Well, time to check the new opti and noticed the rotor was installed incorrectly. Rotated the old opti to the #1 index and the rotor is at approx 7:00 the new one is at 9:00. Has anyone came across this before?
Thanks,
David
Old May 8, 2009 | 09:02 AM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Yes, you can actually install the later optis wrong
The drive will fit into the cam, but the base won't be seated properly.
Check that you didn't bend or crack the base.
Old May 8, 2009 | 10:12 AM
djbraxton's Avatar
djbraxton
Brian,
Thanks for the reply, if you take a opti and rotate the index mark to the #1 on the base the rotor will point to the #1 contact on the cap. The new opti I have the rotor is pointing to the #4 contact. The same applies to the #6 reference. After all of the opti's I have replaced in my cars/friends, this is a first.
Thanks,
David
Old May 8, 2009 | 10:54 AM
jimg's'93's Avatar
jimg's'93
The opti can be installed incorrectly and bolted down?? Hmm. I just knew the coil wire plugged in at about 2 o'clock and everything lined up.
Old May 8, 2009 | 12:22 PM
djbraxton's Avatar
djbraxton
All,
Put the old opti back on and she fired right up. I guess this one could be put in the could it really happen The problem with the new opti is the rotor is not oriented with the indexed notch on the opti drive. Just something to check. Getting a new one shipped to me tomorrow, that is customer service...
later,
David
Old May 8, 2009 | 12:29 PM
96GS#007's Avatar
96GS#007
Yes, it can be installed incorrectly.
Old May 8, 2009 | 03:00 PM
Dudeurgettnavette's Avatar
Dudeurgettnavette
What brand of opti did you buy?
Old May 8, 2009 | 03:34 PM
NEVRL8T's Avatar
NEVRL8T
Old May 9, 2009 | 12:19 PM
djbraxton's Avatar
djbraxton
Received the replacement opti (ACCEL) this morning. The rotor is correctly oriented with #1 index mark on the base. I guess the moral of this story is, remove the cap and check the rotor orientation just to make sure, I never did till now..
David
To Opti rotor
