Need info about porting job.
Old Feb 4, 2002 | 04:47 PM
devilfish's Avatar
devilfish
Default Need info about porting job.
I recall seeing a topic about porting a TPI. The hole procedure whas to port the base, and siamese the runners. I think it whas orginial a topic from a camaro forum. Could annyone help me find this?
Old Feb 4, 2002 | 11:32 PM
devilfish's Avatar
devilfish
Default Re: Need info about porting job. (devilfish)
tt ?
Old Feb 4, 2002 | 11:46 PM
BobMachus's Avatar
BobMachus
Try this link there is one on thirdgen.org also. Mad Max did this to his f-body
Old Feb 5, 2002 | 02:21 AM
devilfish's Avatar
devilfish
Default Re: Need info about porting job. (BobMachus)
thanks :)... So whats the update on this mod? As anyone seen som dyno numbers?
Regards
Old Feb 5, 2002 | 06:45 AM
cohocarl's Avatar
cohocarl
Here's a link I've bookmarked that I think is the one you're thinking about: http://www.thirdgen.org/messgboard/F...ML/001492.html
This link has alot of useful info on making an adjustable f.p.r., polishing aluminum, porting the plenum, etc. No info on siamesing the base on this link, but some good info. http://www.gmtips.com/3rd-degree/dox/tips/tips.htm
I used an air die grinder with a nasty looking wood rasp type tool to do mine. You could use a dremel tool, but it would take 10X as long to do.
Enjoy.
Old Feb 5, 2002 | 09:54 AM
devilfish's Avatar
devilfish
Default Re: Need info about porting job. (cohocarl)
have you seen anny dyno numbers from this mod?
Regards
To Need info about porting job.
