I need to get an alignment before my first track day in my '96 LT4. The suspension is bone-stock and pretty old, I guess. I will be doing suspension upgrades later, but for now, I just want a fairly aggressive track-day alignment.
Can anyone recommend alignment specs for camber/caster/toe for running stock C4 on a road course? Thanks.
but to answer your question, I would(and have) run max front camber possible(I did not run mine symettrically) 1/32 toe out, max castor; in the rear -1, 1/16 toe in.
Some shops are total garbage so I hope you get a decent place. This is what I use:
1.5° neg per side, front. This is with all the shims removed.
6° caster per side.
1/32" toe out per side.
Rear:
1.0° neg camber per side.
1/16" toe in per side.
You may want to take the spacers out ahead of time and save them the labor and you the cost of it. A normal alignment at the good place I found is $80 and they only charged me $5 extra for all the extra they put into it. They were able to get it exact.
your first track day: buy suntan lotion, and enjoy the day.
your 2nd track day: flush the brake fluid with ATE blue
your 3rd track day: get some decent pads.
your 4th track day: yank all the aligment shims.
Larry -
I have been running track days for 6 years, and road racing for 2 years -- I hold an SCCA National Competition License and a NASA Competition License. What I'm talking about is my Corvette's first track day, not mine.
I run 1/4 total toe out in front [1/8 per side]
6 castor
1.4 neg camber front
rear 1/4 total toe in
1.3 neg camber.
Per your other post: try to locate a pair of used 17x9.5 sawblades or equiv to run on front so you can rotate. Its a cheap alternative to buying zo6 wheels or having to deal with different size wheels and tires front/rear. You should be able to locate a pair of stock 17x9.5s for $100 no problem. Heck, if you were closer I have a pair of 90 model 17x9.5s that are very ugly, but round and true I'd let go for next to nothing.
I look forward to following your progress! Lets see what an Ol' C4 can do in the hands of a driver with some good experience. Do you document any of your track work? Video's etc?
Is is a street-driven car? If so, I wouldn't go too far away from the VB&P "Advanced Street" settings until you get a feel for what the car is doing. Expect some understeer with this alignment, but even just adding poly bushings in the sway bars will be a big help ans would something like Bilstein Z51 shocks. You didn't say, but does your car have the Z51 suspension??
It's a compromise for handling and still getting decent tire wear. Zero toe would work for some tracks and still not want to be twitchy on the street. Maybe 1/8" total toe-out would be OK on the street. Roads that have ruts from heavy traffic will be a PITA to drive with too much toe-out.
I do drive it on the street, but only back and forth to the track. It's not a daily driver. I have a high tolerance for driving race-prepped cars on the street, it doesn't bother me.
No, I don't think it has the Z51 suspension, the seller didn't say anything about that and he would have said so if it had Z51. I'm going to track the suspension the way it is with a good alignment for a little while, until suspension mods are in my budget (which they are not at the moment with the other things I have to do).
1.3 neg camber.
way too much rear camber. my car was unstable with that much.
I backed it off, and was much happier.
I think I settled with -0.8
I've tried it several ways. I do way more autox than track days and this keeps it twitchy and helps induce oversteer. I guess I could have been more specific that this is the way I like mine set up.
With regards to that VBP alignment page, which would be better for a Z51 1989 Auto driven on the weekends. Daily driver, or advanced street? I'm thinking daily driver, as I'm guessing that is probably close to stock.
I'm gonna get a tire replaced, tire rotation, and a 4 wheel alignment.
