Screw Broken in engine
Old May 9, 2009 | 09:09 PM
TRINIDAVID's Avatar
TRINIDAVID
Default Screw Broken in engine
Hi I have a 1991 vette L98 engine. I was going to change the thermosat to a 180 deg. I took out one screw and it came out fine. I tryed taking out the other screw and it broke?
Anyone have any ideas how to get this broken screw out??
thank you
Old May 9, 2009 | 09:17 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Default Vette
Very carefully drill a hole on the center of the bolt and us an easy out. Always use anti-seize on threads when you put it back together. I always use anti-seize when threading into aluminum.
Corvette Mike
Old May 9, 2009 | 09:47 PM
TRINIDAVID's Avatar
TRINIDAVID
What is a easy out ?
Old May 9, 2009 | 09:48 PM
M. Schumacher's Avatar
M. Schumacher
I'll second that, and stress that you must hit dead center with the hole. You only get one shot at it. If there is anything sticking out, filing it flat will help.
Common screw extractors...
Old May 9, 2009 | 09:52 PM
TRINIDAVID's Avatar
TRINIDAVID
what is easy out ??
Old May 9, 2009 | 09:53 PM
TRINIDAVID's Avatar
TRINIDAVID
they broke in the engine now what can I do ???
Old May 9, 2009 | 10:08 PM
CorvetteMike2024
Corvette Enthusiast
Default vette
PM sent
Old May 9, 2009 | 10:13 PM
sampaschal's Avatar
sampaschal
I hate to be discouraging, but it sounds as if you have never done anything like this before. Not knowing what an easy out was was the first clue. I would suggest that your next step is to have the car towed to a mechanic who is competent.
You may want to brace yourself for some significant cost. If the manifold has to be pulled or in the event the bolt cannot be removed, a new manifold.
When working with aluminum, there isn't much room for error. Always...and I stress always use studs in aluminum if you can...secondly, when working in the water jacket..the studs should be stainless steel...and always use anti-sieze regardless of the situation. Spark plugs in particular should be installed with anti-sieze.
Best of luck...the learning curve is steep and expensive
Sam
Old May 9, 2009 | 10:38 PM
pablocruise's Avatar
pablocruise
You can add some gentle heat with a oxy/accetylene torch.
Be very judicious with it tho.
(while using the easy-out)
Old May 11, 2009 | 05:33 AM
frenchyoliver's Avatar
frenchyoliver
This is why I always spray wd40 or marvel mistery oil over any screws 24h before work
Old May 12, 2009 | 05:08 AM
sampaschal's Avatar
sampaschal
Then when you break them off....they leave a greasy spot....
Old May 12, 2009 | 08:15 AM
ChrisWhewell's Avatar
ChrisWhewell
thank you
I'd pull the motor.
Old May 16, 2009 | 10:29 PM
gmc's88vette's Avatar
gmc's88vette
I had a about the same issue and made my repair today. I had a bolt hole clean up bit break off in one of my tstat bolt holes. I removed the air plenum so I cold access the area more easily. I started drilling as close as I could get to center of the broken piece with a very small drill. Then I increased bit sizes until I drilled out all of the broken bit except for the threads. The I used a awl and hammer and knocked the threaded piece into the center of the hole. Then I use the largest drill and drilled thru that debri. Every time I drilled I use a magnet to clean up the drill debri to keep the hole cleaned out. It took about an hour but it worked out fine for me. When I got all the pieces out I used a tap and cleaned up the threads for the bolt hole. I am not a great mechanic but I took my time and used my head and it worked our well for me. Hang in there and lose your cool.
To Screw Broken in engine
