ABS System Test Repeating
Old May 10, 2009 | 08:41 PM
gmerrill's Avatar
gmerrill
Default ABS System Test Repeating
Occasionally the ABS system test that normally occurs once at approx. 3 MPH, will happen every time the car slows to 3 MPH. This may occur 10-12 times while driving when I slow to stop. The brakes seem to work fine. This is on a 1988 Vette. Any ideas?
Old May 10, 2009 | 08:44 PM
jfb's Avatar
jfb
Most likely the ABS computer is at fault. Call around to Chevy dealers and see if you can find one that still has a C4 ABS tester, it will at least find where the problem is.
Old May 10, 2009 | 08:51 PM
gmerrill's Avatar
gmerrill
Thanks for the response. I will see if I can find a tester,
Old May 25, 2009 | 08:47 PM
gmerrill's Avatar
gmerrill
Default Found The Problem
The problem turned out to be a wheel sensor. The wheel sensor was on the left rear and tested fine with my hand meter. I was suspect of it because the wheel bearing on this wheel was bad and I replaced it a month ago. It was driving me crazy. Hope this helps someone in the future.
To ABS System Test Repeating
