maf sensor
Old May 12, 2009 | 06:10 PM
tankman's Avatar
tankman
Default maf sensor
Will a 1985 maf interchange and work on a 1987 'vette? Thanks.
tankman
Old May 12, 2009 | 08:25 PM
floridamale's Avatar
floridamale
From what I have seen on here about this subject it should work. The aftermarket guys list just one MAF for the L98 motors. The burn off for the 85 year is controled through the ECM, the rest of the years have a 2 relay system, but I believe the difference is in the wiring and not the actual MAF it just gets it signal a different way. I'm sure some one that has replaced one will chime in
Old May 12, 2009 | 08:57 PM
tankman's Avatar
tankman
Thank you very much.
Old May 12, 2009 | 10:20 PM
williammackean's Avatar
williammackean
St. Jude Donor '07
According to these guys, they're all the same.
http://www.tpis.com/index.php?module...ir+Flow+Sensor
According to these guys, they're not.
http://www.mamotorworks.com/corvette-3-135-3808.html
No idea what the differences are, or if they matter one bit.
It's a Bosch, and the p/n appears to be the same at Checker, Napa, and the like...
GM Parts Direct says the 88-89 are different than the '85.
To maf sensor
