ABS fuse.
Old May 14, 2009 | 10:40 PM
Z51JEFF's Avatar
Z51JEFF
Default ABS fuse.
Does the ABS system have a dedicated fuse?The ABS is dead in my 91 and I looked through the FSM briefly and the only fuse I see is one shared with several courtesy functions.
Old May 14, 2009 | 10:45 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Did you look inside the fuse panel and check for an ABS fuse?
My old 86,there was red number 10 fuse that had the brake name under it in the fuse area.It may be different on a 91 but see if you have one there.
Old May 15, 2009 | 07:03 PM
milsurpman's Avatar
milsurpman
The Ebcm is powered up from the 10 amp fuse marked brake at the lower left of the fuse box above the 20 amp stop hazard fuse. Send me a pm about your symptoms and what you have done and I will help you ts the system. Most of the time its a relay failure of one of the three.
Old May 15, 2009 | 07:11 PM
milsurpman's Avatar
milsurpman
yep its the same on the 90 and 91. The 2s micro is really not a whole lot different then the older 2s but the improvements made were substantial.
Old May 16, 2009 | 10:50 PM
Z51JEFF's Avatar
Z51JEFF
I sent you an email.
To ABS fuse.
