I'm using ARP 3 1/2" long studs with the open end long shank lug nuts so the stud can come through. ARP's are very tough and can be bought at any speed shop or through Jeg's or Summit. Pipe
what would the size of the stud be on a 93? i dont want the long ones i want to keep the stock lug nuts. thanks
I wouldn't think you need to be concerned with the OEM pieces unless you've reason to believe they could be "stretched/fatigued"! I've seen though wheel studs replaced for just "maintenance"! Good idea? Why not!
You could purchase new GM/OEM or perhaps Dorman by brand. If you need dimensions you could use those advertised by Dorman for their part # 610-254. That will give you the splined diameter, shoulder length and you could use the length as a guide. The OEM/GM would have the "dog point" some aftermarket might!
Here's a link to the Dorman product with a "generic" image:
I would think with the notorious breakage of rear end parts on the C4 with good traction and serious power you would see a spindle or half shaft break before studs (any C4 guys out there breaking studs?). So I'd say save your money for spindles and halfshafts as opposed to spending it on new studs.
i have changed the rear wheels a lot and there might be some stretching going on. i like to bullet proof things and studs are cheap, thanks for the info.
Gotcha, makes sense. BTW what kind of power do you think you're putting down?
