Pedal assy. ?
Old May 15, 2009 | 10:04 PM
pipe's Avatar
pipe
Default Pedal assy. ?
I'm changing my 88 over from a manual to a auto trans. I'm going to remove the clutch pedal assy. from under the dash. I have the auto brake pedal assy. ready to bolt in. Where does the auto pedal assy. bolt in at? It's not different under the dash for a manual car than an auto is it? Pipe
Old May 15, 2009 | 10:58 PM
James93LT1's Avatar
James93LT1
Veteran: National Guard
On my 93, the manual brake pedal assembly mounted the same the auto brake pedal assembly mounted.
Clutch pedal assembly was a seprate assembly and mounted on its own. Should be just a removal for you.
