Question about the rear spring cushions
Old May 16, 2009 | 02:56 PM
nobull66's Avatar
nobull66
Default Question about the rear spring cushions
I have a question about the rear spring cushions how far do you tighten them up? On the old ones there's a cotter pin on the bolt and the nut is right there with the cotter pin but on the driver side the nut is higher on up from the cotter pin. Do i put the new ones back on the same way?
Old May 16, 2009 | 03:11 PM
jon0108's Avatar
jon0108
Depends on how low you want your rear to be. The more you tighten up the higher your ride height is going to be. Its like trial and error. On my the drivers side nut is alot higher than the passenger side nut in order to even out the rear.
