maybe im clueless
Old May 16, 2009 | 05:59 PM
EMBPILOT's Avatar
EMBPILOT
Default maybe im clueless
OK, I did a water pump and opti on my 94. Since then it has leaked and I removed the pump and re did it. It's still got a small leak but I cant find it anywhere. Any ideas? I did a fine job and was sure to torque bolts done etc. but is there any tricks or oddities of doing this? I.E. thread locker or RTV on bolts etc.? thanks
Old May 16, 2009 | 07:48 PM
tim32920's Avatar
tim32920
Did you get a new water pump? Sounds like you have a crack.
Old May 16, 2009 | 07:51 PM
96vetteLT4's Avatar
96vetteLT4
you have to use thread sealeant for the bolts that go into the water pump, failure to do this will result in a steady drip drip drip, ive seen a few that had this problem that was fixed with thread sealant on the bolts....G
To maybe im clueless
