1st ride 427ci
The drive was to get to the dyno place near me so I could fill in the RPM gap at WOT better. The car of course had other plans. After a 30 Min fun drive, the dyno awaited us. The car of course refused to run while on the dyno. Even filled the gas tank with 5 gal in an effort to fix the problem. It just would not run. So after an hour, I added two quarts of oil (I had a severe leak but always had good pressure) and drove home. That's right, I drove to an from the dyno but could not complete a run on the dyno. That's me in a nut shell.
The motor is a 427ci sbc with 1pc seal. I find this amusing because people end up in predictable categories: 1) what's a cubic inch, 2) a 427ci won't fit so he's lyin, 3) 1 pc seals don't exist for anything outside LT1, so that's how you do that. I won't even go into the fact that the intake/head is port matched to FP1298/LT4 ports.
My current issues: 1) thought I could get away with my abnormal stock long clutch slave/master travel have to put down the money for the gold plated Mcleod, 2) strange oil leak that effects idle, 3) odd relationship between warm oil and VE table changes not being adjusted by coolant tables, and 4) cooling fans not coming on at all.
Mods are: ported AFR 227cc heads, MRIII, 242/248 cam, 4.125" bore gm racing block, HV oil pump, mcleod twin street pull, ZF6 conversion, 3.73 ratio, 58mm TB, ATI balancer, TD shaft rockers, cheap leaky Al valve covers, hooker header, custom by me xpipe and 3" exhaust, hooker aerochamber mufflers.
Mods waiting for install are: Crane ignition box, MSD ext coil, SSBC electric vacuum boost, new master cylinder, & small 180hp nitrous kit.
Luckily divorce is not imminent.
It is always nice to see someone else building a motor. I myself will be curious to see how much power your combination makes.....
I built somewhat of a similar motor, but you went with more cam/heads.
What is your compression ratio?
