Know enough to be dangerous!??
Old May 17, 2009 | 05:40 AM
C5rider's Avatar
C5rider
Default Know enough to be dangerous!??
I've got a modified 85 with an LT1 running an 89 computer with a crank trigger. It's got a frequency-based MAF and an MAFTranslator to make it work with the computer. It also has a Vortech supercharger.
The only issue I have is that the car goes way rich when I stomp the throttle. Driving around town, it drives great. I'd just like to finally tune it for some hp and have considered either another trip to the tuner or, getting an Ostrich 2.0. I don't see a lot of mods down the road and the only thing that I'd like to address at this time is the WOT A/F ratio. I think its the fuel enrichment that is needing "tweaked".
My question is whether folks who have used this product feel that it would be worth it to invest in one or, simply travel the couple of hours to the tuner? Any input appreciated.
Old May 17, 2009 | 11:56 AM
c-4 lhozwalte's Avatar
c-4 lhozwalte
i dont anything about a/f maps so for me id be makin the drive to tuner.lot safer than trying to tune wot maps without a dyno.then again theres only one way to learn that stuff and thats to get your hands in it
Old May 21, 2009 | 05:38 PM
ZD1's Avatar
ZD1
Seems as though you have a very confusing "ride". The MAF translator is probably helping you more than you can realize. The MAF provide "perfect" volume data for engine loading. On the other hand, when you go into power enrichment (PE) the PCM ignores it's sensors and throws more spark and/or fuel.
So the way to fix this is to get your VE tables right. Get the tuning stuff so you can do it yourself (WBO2, datalog, and tuner). The S/C is going to drive you wacky until you can figure out how to monitor (and plan) how much more air it is going to push into the enginer
To Know enough to be dangerous!??
