Is this normal
Old Feb 5, 2002 | 05:17 PM
95DropTop's Avatar
95DropTop
Default Is this normal
I have a 95 auto and it cruises at 80mph right around 2000rpm. That seems a little low to me. Anybody? :confused:
Old Feb 5, 2002 | 05:34 PM
NoWorries's Avatar
NoWorries
Default Re: Is this normal (95DropTop)
You've just got the taller gear set, 2.73 to 1 if I'm not mistaken for that year in convertible. Scorp know's, he'll probably chime in later today.
You've also got the 4L60E which has an over drive of 0.70, and the lock-up converter decreases the cruising rpms by 300-500 rpms.
All this stuff put together gets you a really low cruising rev. :cheers:
Old Feb 5, 2002 | 05:41 PM
Timmy!'s Avatar
Timmy!
Default Re: Is this normal (NoWorries)
I think you have the 2.59's...
Old Feb 5, 2002 | 05:45 PM
BobMachus's Avatar
BobMachus
I would bet 2.59's since mine does 70 @ 2000rpm.
Old Feb 5, 2002 | 05:47 PM
NoWorries's Avatar
NoWorries
Default Re: Is this normal (BobMachus)
Now that I think about it, I turn 1800 rpms at 65 mph, so at 80, that should be around 2000-2100, although I've never thought to check.
I have a 2.59 rear gear.
[Modified by NoWorries, 2:48 PM 2/5/2002]
Old Feb 6, 2002 | 08:38 PM
neekos's Avatar
neekos
This is normal for your gears
Old Feb 6, 2002 | 10:21 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Is this normal (neekos)
With my 6 speed and 3.45's, at 2000 I'm doing around 80, at 2500 I'm close to 100 :eek:
Old Feb 6, 2002 | 10:31 PM
gsvette's Avatar
gsvette
Hoon
Default Re: Is this normal (Mr Mojo)
Yes, it is completely normal. This is one reason why late model Corvettes get nearly 30 Mpg on the highway.
Old Feb 6, 2002 | 10:32 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
:nonod:
Old Feb 7, 2002 | 11:38 AM
95DropTop's Avatar
95DropTop
Default Re: Is this normal (gsvette)
So is my 21mpg average on the computer within normal range??
To Is this normal
