i have a92 corvette six speed. when it reaches temp it acts like its running out of fuel. ive replaced fuel pump,fuel filter twice, and air filter. the computer reads no code errors. before it warms up and starts bogging it runs perfect. can anyone help?
i have a92 corvette six speed. when it reaches temp it acts like its running out of fuel. ive replaced fuel pump,fuel filter twice, and air filter. the computer reads no code errors. anybody have any ideas?
check your injectors with an ohm meter.. they should read 16ohms
report back your readings
Jon
Jon
Jon is the man on this and just helped me with a new injector installation, but one other thing...
If you are on the road when it happens, try disconnecting one injector at a time and reach over and rev the engine to see if it still boggs down. When an injector goes bad electrically, its resistance drops, and it effectively shorts out all of the injectors on that side of the engine.
Also, I hope you used a fuel pressure gauge to troubleshoot the pump(s). They are like $25 on amazon and are invaluable for determining if you have a leakdown or pressure problem.
Jon, should it not say in your ad '86-93'?
92 and 93's are exact same engine, except for the IAC changing in mid year 93.
If it persists after replacing the FI's, check the ICM, O2's and cats, mine started w/the same problem and it has taken me 2 yr's to find and correct all problems, but I was also throwing a code.
remember the recall we are using a different injector for the 93. It is something in the program even though they are the same engines etc.. so we sell a 93 only a 85 only and 86-92 and 94-96 lt1 and another special one for the lt4 all Bosch 3's
