Is my 93 governed
Old May 18, 2009 | 08:29 PM
demon seed's Avatar
demon seed
Default Is my 93 governed
If so do people bypass this or disconnect.
Old May 18, 2009 | 09:04 PM
c4cruiser's Avatar
c4cruiser
There is an ECM-controlled fuel cutoff at about 5850 RPM but the car's top speed will be at a lower RPM than the fuel cutoff. From what I remember about my 92 A4, the shift points for the auto tranny were at or just below the fuel cutoff RPM.
Is your car an A4 or 6-speed? Top speed with a manual tranny car is in 5th gear.
You would need a custom chip burned to change the fuel cutoff RPM and changing the shift points in the auto tranny would benefit. but for stock motors, I don't think there would be a lot of improvement. For a stock LT1, the max HP comes in at around 5000 RPM and max torque at 4000 RPM. RPM redline is at 5500.
Old May 18, 2009 | 11:52 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
Originally Posted by demon seed
its a 6speed auto.
Is that a typo? Or did you really swap in a new trans.?
Old May 19, 2009 | 01:49 AM
demon seed's Avatar
demon seed
no its a 4speed auto with overdrive.
Old May 19, 2009 | 09:35 AM
byedan's Avatar
byedan
yes they are on the rpm side but not top speed. The top speed limiter should be set to 255 on your car
Old May 19, 2009 | 08:06 PM
demon seed's Avatar
demon seed
Wow....pritty sure she'll never see those numbers.I can only get 152mph out of her.
To Is my 93 governed
