Suggestions for Long Tubes
Old May 19, 2009 | 01:29 AM
89Corvette6spdFX3's Avatar
89Corvette6spdFX3
Default Suggestions for Long Tubes
What are some suggestions for long tube headers. I'm looking for something that is easy to install, lightweight, easy to access spark plugs and under $500 with no EGR.
I currently have a set of LPE LT's with all the air stuff blocked off but they are heavy, big thick flange and getting to the spark plugs is a PITA that requires going from top and bottom to get them in or out. Also, I have to loosen these to get the starter in or out.
Old May 19, 2009 | 05:33 AM
Weav's Vet's Avatar
Weav's Vet
For that amount of money probably Hooker, Hedman, or Kooks. Most of the lighter weight ones are 700.00 or more.
Old May 19, 2009 | 04:47 PM
89Corvette6spdFX3
Never heard of Kooks. Any more info on them? Anyone here use them? I'm debating having mine coated and being done with it but the idea of having to jack the car to access the plugs isn't too inviting. Also, the flanges are so thick standard header bolts are kinda short.
Old May 19, 2009 | 05:10 PM
Weav's Vet's Avatar
Weav's Vet
Summit has about any length header bolt you want in stainless steel or iron. They aren't really bolts any more. More like studs you screw into the head and then put a nut on it. I guess you can still get bolts if that is what you prefer. You can also get locking washers. You want that flange as thick as yo can get it. 3/8" is good. I'm in the process of installing Stainless Works headers on my '96.
Do a search on my post and you will find a Poll I started about a month ago. It has some good opinions on headers. You may get some useful info out of it.
Good Luck with whatever you choose.
88BlackZ-51's Avatar
88BlackZ-51
What's wrong with the Hooker (ceramic coated) 1 3/4?
Old May 21, 2009 | 01:56 PM
89Corvette6spdFX3
I found a set of longer bolts on Ebay. I'm just going to take mine and have them ceramic coated.
Old May 21, 2009 | 07:55 PM
Irishpilot03's Avatar
Irishpilot03
I went with Hooker LTs non-coated, had a local shop weld the 02 bungs, then sent them to JetHot. I forget the price, but it was definitely under $700.
Now for "ease" of install, good luck! I had to definitely think of creative ways to route the headers in without banging/snagging them on something.
Old May 21, 2009 | 08:33 PM
Tom 35th anniversary's Avatar
I got Hedmann elites. Had to dimple one tube for clearance, otherwise pretty straightforward install.
Old May 21, 2009 | 11:58 PM
vader86's Avatar
vader86
I would look for Hookers at that price, or a used set of TPiS and have them recoated by Jethot.
Old May 22, 2009 | 02:36 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Hedman's might the the only (coated) header in the price range specified by the OP. Unless a used set is found.
To Suggestions for Long Tubes
