Broadcast Code
Old May 19, 2009 | 10:25 AM
ZumZum's Avatar
ZumZum
Default Broadcast Code
I need to locate the broadcast code on my ECM and have no idea where to look. My car is here in the parking lot at work. Is this something I can easily do there? Any help will be greatly appreciated.
1988 C4 coupe.
Old May 19, 2009 | 01:15 PM
ZumZum's Avatar
ZumZum
Old May 19, 2009 | 02:18 PM
mseven's Avatar
mseven
There is "supposed" to be a tag on it with the entire ecm #(1227165), and another that will have the broadcast code. I think the broadcast code was a 4 or 5 digit no., it's been awhile since I looked at those but the tag should be on the outside of the ecm itself.
Old May 19, 2009 | 02:28 PM
tequilaboy's Avatar
tequilaboy
If its not labelled on the outside of the ecm anywhere, the eprom itself should have a label over the window.
To see it, you will have to first remove the memcal from the ecm and then pry the blue cover off of the memcal.
The bcc should be printed on the label that covers the eprom's erase window, assuming it hasn't already been removed by somebody else.
Old May 19, 2009 | 03:34 PM
ZumZum's Avatar
ZumZum
Ok. thanks.
I appreciate the help.
To Broadcast Code
