Miss at Idle
Old Feb 5, 2002 | 09:59 PM
Too Slow '90's Avatar
Too Slow '90
Default Miss at Idle
My '90 has a slight miss at idle only. When I accelerate the miss is gone. I am going to do plugs and wires first. What wires should I go for & how much $? Also what about the cap, rotor etc..? Any hi-perf parts better than oem? Any Ideas if i am chasing the problem in the right direction? Thanks. :chevy
Old Feb 5, 2002 | 10:04 PM
neekos's Avatar
neekos
Default Re: Miss at Idle (Too Slow '90)
check to see if you have a vacuum leak or a clogged PCV valve. Take the PCV valve out and shake it. If you hear a rattle, it is fine. If you don't, it means it is clogged and that may be your culprit.
Old Feb 6, 2002 | 07:28 AM
Too Slow '90
Default Re: Miss at Idle (neekos)
Forgot to mention, already replaced the pcv. Thanks anyway. :chevy
Old Feb 6, 2002 | 08:03 PM
Too Slow '90
??? :chevy
Old Feb 6, 2002 | 10:11 PM
vader86's Avatar
vader86
plugs, wires, cap and rotor are what i would replace, that should fix it.
Old Feb 7, 2002 | 10:44 AM
neekos's Avatar
neekos
Default Re: Miss at Idle (vader86)
I agree. If its been a while since the last tune up, go with that. That will either cure the problem or narrow it down to something else, but take it one step at a time. A tune up never hurts.
Old Feb 7, 2002 | 09:39 PM
Too Slow '90
I have the plugs but for the wires, cap and rotor go stock or aftermarket as I have seen on the forum? :chevy
Old Feb 7, 2002 | 11:35 PM
vader86's Avatar
vader86
stock is fine on a stock motor. Wires you can go aftermarket, for Distributor, i think i would go stock.
To Miss at Idle
