Starting problem when semi warm?
Old May 21, 2009 | 10:44 PM
Andyman11111's Avatar
Andyman11111
Default Starting problem when semi warm?
hey guys. My 88 has trouble starting after it has been driven, and sits anywhere from 40 minutes to about 5 hours. It starts perfectly after sitting over night, or if it has been driven within the past 30 minutes. Any ideas? I was told that the car has "always" done that, but it bothers me and i would like to find a solution.
Old May 22, 2009 | 02:26 AM
Jake Dragon's Avatar
Jake Dragon
Sounds like starter heat soak.
Mine does the same thing. I just have to leave it sit until the temp drops back down below 110 and it will start again. Not good if you have to make a lot of stops in one trip.
Old May 22, 2009 | 04:59 AM
floridamale's Avatar
floridamale
Are you saying it's not cranking or firing up after sitting ?
Old May 22, 2009 | 08:49 AM
Joe C's Avatar
Joe C
leaking injectors -
try flooring the gas pedal before you turn the key on, and see if that helps. sounds like your injectors are flooding the engine as the fuel pressure leaks down, and verify by checking the fuel pressure leakdown after stopping the engine. i went thru the same thing on my 85 - only way to solve this is a new set of injectors. check with Jon at FIC. hope this helps...
Old May 22, 2009 | 09:16 AM
Toy90's Avatar
Toy90
I had the same problem with my 90 and it was the injectors as well.
Old May 22, 2009 | 10:27 AM
Andyman11111
It starts, but it takes about a good 4 maybe 5 seconds of cranking. Could this be a serious enough problem to have to replace my injectors?
Old May 22, 2009 | 10:32 AM
floridamale
Yes try what Joe C said but I would check the injectors
Over time it will get worse
Old May 22, 2009 | 10:41 AM
Andyman11111
Ok, would getting them cleaned by FIC fix it? I dont want to buy new injectors if i dont have to
Old May 22, 2009 | 11:30 AM
floridamale
No the ethanol in the gas is eating them up call Jon @ FIC pick up a set of Bosch lll's best deal going he has a sticky top of tech section
Old May 22, 2009 | 12:24 PM
Andyman11111
ok ill probaly do that. theyre only 170 a set, i thought it was 170 per injector. How hard would they be to install? i have the FSM, and a good amount of car knowledge.
Old May 22, 2009 | 12:31 PM
floridamale
It's not a bad project at all many on here have done it. Tere is a video of the
R & R and lots of post also
Old May 23, 2009 | 03:42 AM
Jake Dragon
Different problem.
Mine wont turn over when the starter gets hot.
To Starting problem when semi warm?
