AutoZone Antenna ???
Old May 22, 2009 | 01:57 AM
Binski's Avatar
Binski
Default AutoZone Antenna ???
Does anyone have any experience with installing an Autozone antenna in a 93-96 C4. The Autozone antenna is listed for $59 whereas the antennas from Eklers, Zip and others are around $200. I don't listen to the radio much but it would be nice if the antenna worked. Thanks for any insight.
Old May 22, 2009 | 05:03 AM
floridamale's Avatar
floridamale
I'm not sure about the Auto Zone antenna but if you don't listen to the radio which ever one you get install a switch that stops it from going up & down when it comes on.
Old May 22, 2009 | 07:31 AM
Demonic85's Avatar
Demonic85
Isnt the Autozone one a generic power antenna?
Old May 22, 2009 | 10:47 AM
josephf31's Avatar
josephf31
Default If
it will fit it will work, but it doesn't sound like a generic power unit will fit in the fenderwell area.
Old May 22, 2009 | 11:23 AM
jeffp1167's Avatar
jeffp1167
when I pulled my rear bumper cover from my 90 my antenna fell on the ground. I am going to try a after market one in it and will let you know how it goes.
Old May 22, 2009 | 11:31 AM
92ZR1WANNABE's Avatar
92ZR1WANNABE
It fits just fine, both in the hole where your original antenna went and in the fenderwell.
I have one on my 92 for the same exact reason.
Old May 22, 2009 | 04:23 PM
Binski's Avatar
Binski
Thanks I will give it a try.
To AutoZone Antenna ???
