RPO Codes Revisited
Old Feb 6, 2002 | 11:06 AM
my02cents's Avatar
my02cents
Default RPO Codes Revisited
Here are all my RPO Codes:
AG9
AU3
A42
A51
BGR
B16
CC3 - Removable Roof
C49 - Defogger, Rear Window, Electronic
DL8 - Heated Outside Mirrors
D3X
098
E52
E9Z
HE3
K34
K61
L83 - EFI Engine, 5.7L V8 (1984 Only)
MD8 - Transmission, Auto, 4Speed THM 700-R4
MXO
NA5
NB1
QZD
UQ4 - Speaker System, Bose
UU8 - Radio, AM/FM Stereo, Cassette, Dolby, Clock, ETR
V73
Z6A - Defogger, Rear Window and Outside Mirrors
1AZ
33L
33U
741
742
As you can see... I am missing the definition to a lot of them!! Namely my GEAR RATIO. :mad If you can help fill any in, I would really appreciate it. :) Thanks!
Old Feb 6, 2002 | 11:30 AM
dgoodhue's Avatar
dgoodhue
Default Re: RPO Codes Revisited (Red84CrossFire)
AG9 Power Driver Seat
AU3 Power Dor Locks
A42 Adjuster, 6 Way Power Seat
A51
BGR Plant Code, Bowling Green Kentucky
B16
D3X
D98
E5Z Speedometer Adapter, Delete
E9Z Speedometer Key, Delete
HE3
K34 Cruise Contol
K61
MX0 Mechandised Transimission, Automatic
NA5 Emmision System, Federal Requirements
NB1
QZD Tires, P255/50VR-16
V73 Vehicle Statement, US/Canada
1AZ Order Modification, Orders Sold *Processing
33L
33U
74I
742
33/74 are your ext/int colors, 742 means you have leather trim.
I will look up the other one, the only one that I don't think I have seen before is the HE3.
Old Feb 6, 2002 | 11:34 AM
dgoodhue's Avatar
dgoodhue
Default Re: RPO Codes Revisited (dgoodhue)
A51
B16
D3X Gear-Speedometer Driven (25513049)
D98 Stripe, Body Side Accent and Decklid
HE3 Axle, Rear, 3.07 Ratio
K61 Generator, 97 Ampere
NB1
33L Exterior Color, Secondary, Light Driftwood
33U Exterior Color, Primary, Light Driftwood
74I Interior Color, Carmine
742 Trim Combination, Leather, Dark Carmine
Old Feb 6, 2002 | 11:57 AM
my02cents's Avatar
my02cents
WHOA! Thanks GUYS!! :) :cheers: :eek:
Old Feb 6, 2002 | 12:08 PM
my02cents's Avatar
my02cents
I can't believe you found that. :) Thank you very much. I guess it's time for new gears then.
Old Feb 6, 2002 | 02:54 PM
CFI-EFI's Avatar
CFI-EFI
I believe that I posted in response to your earlier thread, that "F", "G", and "H" codes could deal with the rear axle.
A51 Seat Front Bucket, Non-Reclining
B16 See below
NB1 Emission Control, Closed Loop
33L & 33U The "L" stands for Lower and the "U" stands for Upper
I don't show a "B16" for ANY application. The only "B" code that remotely matches and makes sense is "B18". It can have different meanings, depending on the year. For 1976 -1987 it simply designates: Ornimentation, Interior (Deluxe)
It looks as though your "quest" is complete. It STILL wouldn't hurt to count your driveline revolutions. Who knows what has been changed in the last 18 years. There is one guy who insists that the '84, Z51 came with four 9.5" wheels, just because he measured HIS. As far as your rear axle is concerned, the "best" code you could have come up with, would have indicated a 3.31:1. Also, realize that these RPOs don't necessarily designate "options", but equipment, whether, optional or not. Your rear axle code is a case in point.
[Modified by CFI-EFI, 1:20 PM 2/6/2002]
Old Feb 6, 2002 | 03:06 PM
Bluevette85's Avatar
Bluevette85
Check out this site:
http://corvetteactioncenter.com/tech/rpo.html
Old Feb 6, 2002 | 03:43 PM
my02cents's Avatar
my02cents
Default Re: RPO Codes Revisited (CFI-EFI)
Thank you. :) CFI-EFI... Thanks for your help. Maybe I read that B-code wrong. I will look again. I found out today that my heads are not stock... so who knows about the rear end. I will have to do what you say and rotate them. :)
Thank you everone.
To RPO Codes Revisited
