Service Engine Light
Old May 23, 2009 | 03:21 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Default Service Engine Light
My CE LT4 with Elliot Portworks LE2 package triggers the engine light like every three weeks. The "misfire" code comes out and yes I have a OBD scanner and I can delete the code.
What it could be? The ECM was tuned, all parts are new, plugs are new...
The Vette runs great and STRONG. Would the IAC or TBPS have anything to do with this? That part is old/original
Old May 23, 2009 | 03:28 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Can you datalog while driving and try to "catch" the code when it happens?
Old May 23, 2009 | 05:45 PM
PLRX's Avatar
PLRX
2017 C4 of Year
I'll try while driving for now and in the garage I collected this data:
P0300 Random Misfire Detected
Freeze Frame Data
Fuel Sys 1: CL
Fuel Sys 2: CL
Calc Load (%): 4.31
ECT(°C): 79
STFT B1 (%): 0.78
LTFT(%): 3.13
STFT(%): 2.34
LTFT(%): -1.56
MAP(kPa): 67.00
Eng RPM: 737
Veh Speed (km/h): 0
MAF(g/s): 11.26
TPS(%): 0.00
Reading at the idle Eng RPM (I was at a stop light) in the code reader and what is in the tach are two numbers. Obviously it is too low, right?
Old May 23, 2009 | 07:38 PM
PLRX's Avatar
PLRX
2017 C4 of Year
Anybody?
Old May 23, 2009 | 09:37 PM
steve40th's Avatar
steve40th
Originally Posted by PLRX
Anybody?
Right now it indicates random misfires. If the last number of the code were a 3, it would indicate cylinder #3 is misfiring.
The underlying cause is often a lean fuel condition, which may be due to a vacuum leak. Check hoses, wires etc. Its a ****ting intermittent fault.
in the intake manifold or unmetered air getting past the airflow sensor, or an EGR valve that is stuck open(your is LT4, no EGR, correct but a plate back there).
Old May 23, 2009 | 09:40 PM
steve40th's Avatar
steve40th
Also, check plug wires, and plugs with the car at night with hood open and no lights. Look for a arc from wires and plugs.
Old May 24, 2009 | 06:34 PM
PLRX's Avatar
PLRX
2017 C4 of Year
I haven't drive her yet because I'm doing the rear window, the rear pillar and targa weatherstrips but even tough I torque everything to specs (FSM) the EGR plate, the MAP, The TB and the Air Pump bolts were loose. I hope the intake manifold itself is not loose, I torque that SOB 4 times using the proper sequence.
I did apply dielectric grease to the plugs and to the opti's terminals but I'll check on those tonight
BTW, the targa's weatherstrips were a P A I N I N T H E A X S Z
Old May 24, 2009 | 10:12 PM
steve40th's Avatar
steve40th
Dont tell me it is a pain. I am going to be doing the targa and the door seals etc. The window is fine, but TARGA is bad.
Old May 25, 2009 | 03:41 PM
PLRX's Avatar
PLRX
2017 C4 of Year
Steve,
http://forums.corvetteforum.com/c4-g...therstrip.html
Old May 25, 2009 | 05:14 PM
steve40th's Avatar
steve40th
That helps big time. Thanks
To Service Engine Light
