INFL REST light
Old May 25, 2009 | 10:10 PM
Walt Robinson 7's Avatar
Walt Robinson 7
1st Gear
Default INFL REST light
The INFL REST light on my display panel comes on. What does this indicate and how can it be reset?
Old May 26, 2009 | 09:25 AM
UNCLEBILL's Avatar
UNCLEBILL
I see that you have a 1992. This is a common problem on 1990's only. You will have to pull the code(s) to see what the problem is and to see if its a ground short on the left or right frame rail sensor. Does your seat belt lite stay on also? Will need to have this info first to direct you how to fix or just reset.
