Ed Wright stage ll chip
Old Feb 7, 2002 | 12:21 AM
TOEMAN's Avatar
TOEMAN
Default Ed Wright stage ll chip
Had my car dynoed two weeks ago with a wide band. 252 rwhp 344rwt but was way rich, in the mid 11's to 12 at the upper rpm range. Dropped the fuel pressure down from 45lb to 43lb, made the best run but the air to fuel graph changed very little, looked as if it didn't respond. Now with the stage ll chip will the car react to a fuel pressure change more or about the same as the stock chip. The stage ll on my scanner showed that the timing was increased, the fan came on earlier, and the voltage dropped a few from the stock chip, haven't dynoed again yet. Just wondering if the fuel adjustment now will have a big affect.
thanks
TOEMAN
Old Feb 9, 2002 | 12:44 PM
TOEMAN's Avatar
TOEMAN
Default Re: Ed Wright stage ll chip (TOEMAN)
I wonder if I am not phrasing this question right or something. More than 30 people looked but no one replied. Just wondering or noboby knows the answer.
Ken
Old Feb 19, 2002 | 11:59 PM
olephart's Avatar
olephart
Hi Toeman. I guess we are neighbors. Too bad an "expert" hasn't answered you. I am certainly not one, nor do I play one on TV.
I do have an uninformed opinion. Once Ed works on your computer, you have no idea what is going on and he owns you. He locks the code so nobody can read it and he won't tell you what he has done.
You have two choices. Continue with ED or another tuner - send scans, dyno sheets and money. Or, see if you can get back to stock and start programming.
I believe Ed will eventually get pretty close. I think you could too with a little help from the guys on this forum.
Good luck
Oops, Just realized you had a canned chip. I don't know if he locks those chips. He does lock the PCM's. I hear there is not a lot of changes in those chips.
[Modified by olephart, 10:05 PM 2/19/2002]
Old Feb 22, 2002 | 10:50 AM
white 91 roadster's Avatar
white 91 roadster
Toeman for what it's worth my 91 run's on the rich side to, bone stock chip, fuel presure at 42lbs . now when I say rich i'am going by my barly pasing the polution test reading's. what scaner are you using as I need to pick one up.
Old Feb 22, 2002 | 12:37 PM
Warlock's Avatar
Warlock
No matter who does what to your chip, it should no affect how it reacts to changes in fuel pressure.
Old Feb 22, 2002 | 07:50 PM
89gta383's Avatar
89gta383
Default Re: Ed Wright stage ll chip (Warlock)
I have an Ed Wright chip that I bought before I got my prom equipment, and I can see his .bin file fine using Craig Moates scanner program.
He actually didn't change much in my chip but add craploads of timing everywhere.
I probably should pull the chip and see if it matches to the aldl dump though...
Old Feb 22, 2002 | 10:34 PM
ZROne's Avatar
ZROne
Default Re: Ed Wright stage ll chip (89gta383)
You should probably pull the chip he screwed with and use Data Ease or another program to tune the car.
Old Feb 24, 2002 | 06:26 PM
Corvette86's Avatar
Corvette86
St. Jude Donor '06
I also purchased a chip from Ed Wright for over $400.00. After running his chip for a very short time I had problems. Not having a whole lot of spare time on my hands I thought that was my quickest way to get my L383 running its best. Wrong answer! Headache after headache! I gave up with the chip and purchased tunercat, pocket programmer, diacom plus, and rom emulator. It took awhile to get up to speed understanding the different tables how they intereact with each other but it's paying off now. I love running my car with my laptop and seeing how all the changes I make work (or don't work together).
My advice...pair up with someone in your area and have them help you build a chip worthy of all your hard work. You'll be glad you did. Trust me:)
Old Feb 28, 2002 | 01:03 PM
TOEMAN's Avatar
TOEMAN
Default Re: Ed Wright stage ll chip (Corvette86)
Thanks for all the advise
Ken
To Ed Wright stage ll chip
