radio /fuse link
Old May 27, 2009 | 08:38 PM
RLG's Avatar
RLG
Default radio /fuse link
I think I found the fuse link that I fried, I replaced it with one that you can put a regular fuse in.
This link runs the radio,power door locks and seats.
I put a 10 amp in and it blew. I think I need a 30 amp , but thought I would get some feedback before I put it in . That's about 10 minutes from now!!!!
Old May 27, 2009 | 09:22 PM
Hooked on Vettes's Avatar
Hooked on Vettes
To fix it correctly you need to solder in a 14 AWG fusible link.
You don't replace a fusible link with a regular Autofuse.
You would use a Maxifuse. The wire in the circuit is 10 AWG so you would use no larger than a 60 amp Maxifuse and the proper holder for it.
If you don't repair the problem correctly you could have an electrical fire.
Old May 27, 2009 | 09:34 PM
RLG's Avatar
RLG
I used an ATC type with a weatherproof cover. It didn't matter anyway, I put a 25 amp fuse in the holder it didn't blow , but the power seats still don't work the door locks don't work and the constant 12 volts to the radio isn't there.
I am about ready for a fire, it's insured!!!
All was well until that damn starter went out.
I have read this FSM and I can't figure out where the common denominator is with these items.
Old May 27, 2009 | 10:05 PM
RLG's Avatar
RLG
One more thing , the fuse link that comes from the starter relay shows to go to the A/C system and that is working fine, does it carry current to these other areas?
Old May 27, 2009 | 10:10 PM
RLG's Avatar
RLG
does fusible link A come off of the Jump start junction box? and which one is it, Maybe I replaced the wrong one.
Old May 27, 2009 | 10:27 PM
Hooked on Vettes
Are you working on a 90 Vette?
Fusible link A provides 12 volts to the following items.
1) Fuel Pump relay
2) Radio Fuse 10 amp.
3) Stop Hazzard fuse 10 amp.
4) Brake fuse 10 amp.
5) Defogger Breaker 30 amp.
6) Power Acc. Breaker 30 amp.
7) Hatch Breaker 30 amp.
8) Theft fuse 15 amp.
9) Ignition switch
As you can see, a 25 amp. fuse doesn't cut it.
As far as I've seen the fusible links aren't labeled at the jumper block.
Old May 27, 2009 | 11:01 PM
RLG's Avatar
RLG
1) Fuel Pump relay
9) Ignition switch
yes it is a 90, what do you mean by not cutting it, it didn't blow the fuse. Wouldn't the fuse blow if it was to light??
Thanks for the help.
I usually don't get this bothered by this stuff , but this is really getting to me.
Old May 27, 2009 | 11:04 PM
Hooked on Vettes
The Starter has 3 wires going to it.
1) Purple wire to Starter Solenoid from Starer Enable Relay.
2) Black wire from Battery to Starter Motor.
3) Fusible Link K from same point as the Black wire on the Starter and if you have C60 Manual AC goes to the Blower Motor Relay. If you have C68 Auto Climate Control it goes to the Blower Motor Control Module.
Old May 27, 2009 | 11:09 PM
RLG's Avatar
RLG
I am getting about 9.75 volts at the fuse block for the 10 amp fuse,
Old May 27, 2009 | 11:10 PM
RLG's Avatar
RLG
I have the C68 and the AC works and the blower seems to function properly.
Old May 27, 2009 | 11:14 PM
Hooked on Vettes
If you replaced the correct fusible link you would have 12 volts at all of the fuses I listed.
If you don't measure 12 volts you either replaced the wrong fusible link or the fusible link is good and there is a bad connection at the jumper block.
Disconnect the negative battery cable.
Remove the nut holding all of the wires and clean the terminal lugs.
Removing the side gill panel makes the job easier.
Old May 27, 2009 | 11:15 PM
RLG's Avatar
RLG
I just don't understand why these 3 components wont work when they did before I replaced the starter. I did move the starter wire with the battery hooked up and it sparked. that's why I replaced it. It did blow the 25 amp fuse to the wipers, which also powers the radio.I replaced that fuse and the wipers work fine.
Old May 27, 2009 | 11:16 PM
Hooked on Vettes
The Blower Motor works off of fusible link K. Fusible link K gets 12 volts from the Black cable on the starter motor. The Black cable connects directly to the Battery.
Old May 27, 2009 | 11:17 PM
RLG's Avatar
RLG
We are thinking alike, I bought a new jumper block today and replaced it, cleaned all connections
Old May 27, 2009 | 11:21 PM
Hooked on Vettes
The 25 amp. wiper fuse is feed from Fusible Link A. If that fuse blew, the ignition switch must of been in the ACC or Run position.
All of your problems appear to be no 12 volts from Fusible link A.
Old May 27, 2009 | 11:22 PM
RLG's Avatar
RLG
I do have an after market radio but it was working perfect before the starter incident.
Benny42's Avatar
Benny42
Replace the fusible link feeding this, or find the loose connection. This is where to focus. benny
To radio /fuse link
Old May 27, 2009 | 11:25 PM
RLG's Avatar
RLG
I could have left the switch on when I wiggled the wire that caused the spark. I tried to start it then went over and pulled on the wire.
Old May 27, 2009 | 11:30 PM
RLG's Avatar
RLG
I agree Link A which one is it? I guess i replace the wrong one. I would rather not cut wires to find it if someone knows which one it is
Thanks again for the help.
I Hate electrical problems, I fought this same battle with my 69 GTX until year one finally came out with the wiring harnesses.
Old May 27, 2009 | 11:31 PM
Hooked on Vettes
Are you saying the wipers still work? Can you verify that again?
The Purple wire at the Starter Solenoid gets 12 volts from Fusible Link A.
