Service engine light problem
Old Feb 7, 2002 | 12:53 AM
BAdAzZV8's Avatar
BAdAzZV8
Default Service engine light problem
Well my car idles rough after I start it up. After the service soon light comes on, my idle becomes normal. I was wondering what is going on, and why the car idles better when the service engine light comes on. I have no cats, so I'm thinking that has something to do with it, I was just wondering if I didn't have cats why would the idle be rough, and then become normal when the service engine light comes on.
Thanks for the help.
Old Feb 7, 2002 | 12:54 AM
vader86's Avatar
vader86
Default Re: Service engine light problem (BAdAzZV8)
youll should pull the codes and see what it says first
Old Feb 7, 2002 | 12:57 AM
BAdAzZV8's Avatar
BAdAzZV8
Well I tried jumping pins 4 & 12, but no codes popped up on my car. So, I don't have any way of checking the codes. I was hoping someone on here could help me out before I payed a dealer to check what's wrong with my car.
Old Feb 7, 2002 | 12:58 AM
vader86's Avatar
vader86
I thought the paper clip thing didnt work on OBDII cars, or am i wrong?
Old Feb 7, 2002 | 01:02 AM
BAdAzZV8's Avatar
BAdAzZV8
Well being a '94, I thought it was still possible. The build dat on my car was 9/93. some people said that they changed to OBDII on late '94 models.
I'm still not sure on this whole code finding thing, so anyone with some info please post.
Old Feb 7, 2002 | 02:05 PM
Red Dwarf's Avatar
Red Dwarf
You have an OBD I. The II'S came out in late95 & were standard in 96. The 95's had a few parameters for the II, I think they were just for post compliance testing.
I sent you some stuff that may help pulling your codes. :cheers:
Old Feb 7, 2002 | 03:10 PM
BAdAzZV8's Avatar
BAdAzZV8
codes:
C12
H62
H64
H65
Holy poopie, I have 4 codes.
Old Feb 7, 2002 | 05:39 PM
David-F's Avatar
David-F
looks like you have problems with your right fron HO2 sensor, but because it's had problems you may have carboned up the spark plugs also I would start with a new HO2 sensor and a clean set of plugs and see what happens.
David Fulcher
P.S. also check to see if you oil temp sensor is unpluged or broken off it's above the oil filter on the left rear of the engine.(code 62)
[Modified by David-F, 3:41 PM 2/7/2002]
Old Feb 7, 2002 | 07:56 PM
BAdAzZV8's Avatar
BAdAzZV8
Default Re: Service engine light problem (David-F)
I just replaced the plugs, however one was all carbon'd up b/c it wasn't screwed in all the way when they were put on. I cleaned that up and reinstalled it. I may have problems with O2 sensors though, I'm going to check that too.
Old Feb 8, 2002 | 04:58 AM
DREGSZ's Avatar
DREGSZ
Default Re: Service engine light problem (vader86)
Before I even read through the thread I was guessing O2 sensor.
It's probably the most common thing that will trip your SES light.
Old Feb 8, 2002 | 11:00 AM
Z06 Fever's Avatar
Z06 Fever
Cruise-In III Veteran
Cruise-In IV Veteran
Default Re: Service engine light problem (Evan Ginsberg)
I'm having similar problems with mine. Both O2 sensors have been replaced and I'm still getting the SES light. :confused:
Old Feb 8, 2002 | 12:49 PM
David-F's Avatar
David-F
Default Re: Service engine light problem (Yellow Fever)
Have you scaned for codes and if so what did you have? 96 also has problems with air inject check valves that can give you a SES ligh and not effect running.
David Fulcher
To Service engine light problem
