VATS?
Old Feb 7, 2002 | 02:54 AM
snydcat's Avatar
snydcat
Default VATS?
When I came out of the gas station tonight I turn the key and nothing! No fuel pump noise for a few seconds like it normally does. I'm thinkin the vats just got me :mad so I lock and unlock the doors (worked the last time) nothing. The security light is flashing :confused: because the last time it happened(over 1 year ago) no security light. I'm going to have to have it towed back to my house in the morning( 1/2 mile away ) :mad and order the bybass kit. The only other thing I can think of is the fuel pump because the car has been running like a dog the past couple of days. I also checked the fuses (all good) and for codes, all that comes up is code 12. Anything else I should be checking out :(
Thanks,
Rich
[Modified by snydcat, 1:55 AM 2/7/2002]
[Modified by snydcat, 2:54 AM 2/7/2002]
[Modified by snydcat, 1:59 PM 2/7/2002]
Old Feb 7, 2002 | 10:43 AM
Roar Hansen's Avatar
Roar Hansen
Default Re: VATS? (snydcat)
Hi!
Can't really tell you what the problem is but it's probably not VATS as this was intoduced in 86. Also the VATS does not kill the fuel pump as you described. I know the 85 has the alarm (that flashes the Security-light when not activated) but this will not keep the car from starting as far as I know.
When you turn on the ignition, is it totally dead? As in no lights on the cluster and no heater-fan or nothing ? If this is the case, you may have a problem with the ingnition-switch or as simple as the battery connection.. Just guessing here ...
Old Feb 7, 2002 | 02:44 PM
snydcat's Avatar
snydcat
Default Re: VATS? (Roar Hansen)
I finally got the car started. The first time I tried nothin, the second time she fired up but running really bad! like it's running on 6 cylinders. When she didn't start I had all accesseries, lights, cluster, everything. I have replaced the ignition module and coil within the last six months both A/C Delco, replaced the distributor cap rotor and plug wires a little over a year ago(about 15k miles). The plugs I changed a couple of days ago and checked the wires for arching (all good) when it started running rough and no change. I won't be able to get to my mechanic til Monday, until then any guesses or suggestions on what I should be checking is more than appreciated.
Thanks,
Rich
When I went to get the car this morning at the gas station I turned the corner and I see red stuff all over my car :mad thinking it was paint :cuss . It turned out to be ketchup from one end to the other, every panel,window, wheel, everything :mad . They must have used a gallon, I had to pull my door panels off after washing it to get the ketchup out of the outer window seals :cuss . If I ever catch somebody vandalizing mine or anybodys car I will personally break my foot off in their **** and go get another leg (I have a prothetic Right leg) and repeat the procedure :mad :mad :mad
[Modified by snydcat, 1:47 PM 2/7/2002]
[Modified by snydcat, 1:56 PM 2/7/2002]
Old Feb 7, 2002 | 06:55 PM
TravisD's Avatar
TravisD
Sound a lot like a dead battery/bad alternator.
Old Feb 7, 2002 | 07:58 PM
Husker Vette's Avatar
Husker Vette
From: Are you the bug or are you the windshield.....
Snydcat,
Towards the end of summer my 86 would start first thing in the morning, but after it got warmed up and I stopped somewhere, when I went back to start it again it wouldn't start....... All lights worked, but no ignition.
After getting the bypass kit, it continued to do the same thing.
Put in a new starter, and that cured it for about a week.
Put in another starter with a heat shield, and it hasn't happened again.
Check you battery, but don't rule out the starter......
Old Feb 7, 2002 | 08:36 PM
snydcat's Avatar
snydcat
Default Re: VATS? (Husker Vette)
Snydcat,
Thanks, I will check the battery this weekend but when I turn the key the volts say 12.9 and when it starts it stays at 14.6 for a few minutes and with everything on lights, radio etc. it has never gone below 13.5 :confused:. I'm also wondering way it's running so rough like it's not hitting on all cylinders.
Rich
To VATS?
