Catyltic converter replacement
The AIR pipe that run from near the passenger exhaust down to the cat is the issue. What is the typical connection method for this? The original had a interesting type of crimp on a flared type end that I managed to bend enough to separate it from the old cat. The new cat has just a tube with no special fitting.
What is the typical way of connecting these?
I figured that most folk that upgrade their cat have to go through this and there is some typical fix other than welding? depending on how tight the tubes fit, I wonder if a simple hose clamp might have enough clamping force to hold it firmly. There shouldn't be any real load on it.
just set you heat on the lowest setting a do multiple tack welds all around and do one tack weld on each side at a time. after you have a few tacks then weld them together.
compression fitting on cat.
- cat to tube compression fitting.My cat and tube were 1/2". I added the 2nd fitting about 14" above the cat in a straight section. This allowed me to screw the fitting to the cat where the angle was difficult to start the fitting and the one upstream allowed more room to align the tube (straight). If you ever have to pull the cat it makes it easier to remove if the pipe unscrews. Things are even better if you weld flanges to your pipes and cat so they bolt in and out.
There have been other posts on this and many have just used high temp hose with a couple of hose clamps.
