seal pointers!
Old May 29, 2009 | 02:24 PM
matt_jahn's Avatar
matt_jahn
Default seal pointers!
I was wondering if i could get some of your guys input on an easy way to do this.
I have a pretty good oil leak and its coming from the oil seal on the timing cover, behind the crank pulley. i am hopping i can get at this from the bottom and not have to pull the radiator and water pump and opti to do it.
so any pointers and tips would be greatly appreciated
Old May 29, 2009 | 10:28 PM
matt_jahn's Avatar
matt_jahn
any thoughts?
Old May 29, 2009 | 11:03 PM
aboatguy's Avatar
aboatguy
I'd go from the top and you don't need to pull the water pump or OPTI
All you need to pull is the damper off of the hub and then the hub off of the crank.
I posted about this last week, for my ATI super damper install.
http://forums.corvetteforum.com/c4-t...b-removal.html
To seal pointers!
