power door locks/power seats
Old May 29, 2009 | 09:06 PM
RLG's Avatar
RLG
Default power door locks/power seats
this is an extension from the radio thread
I replaced the fusible link. The radio now works, I get 12 volts to the power acc. breaker, found the Aux fuse block the 15 amp fuse is good for the power doors but i only get about 4 amps out of it.
all fuses in the main block are good.
Still no door locks or seats.
any ideas??
Old May 30, 2009 | 10:57 AM
gw962's Avatar
gw962
You may have already checked, but the only thing I can think of is a ground issue. G202 is on the passenger side kick panel, under the IP.
My first inclination would have been a faulty ACCY breaker, but if you get 12v out of it to the door fuse, that eliminates that possibility.
