Air Pump problem
Old May 29, 2009 | 09:08 PM
Dolfan's Avatar
Dolfan
Default Air Pump problem
OK, I just picked up my pump off the bench that has been off as I rebuild the top end. I went to give it a spin and nothing
I believe that in my zest for only clean good looking parts going back on the engine I suspect some water may have got to the unit, maybe temporarily seizing it????? I was thinking to shoot a little WD40 or PB Blaster into the pump and see if it frees up, sound like a good idea?
I just can't believe I might have to fork over $50 for a part that I don't even want
Old May 29, 2009 | 09:31 PM
M.J.L.'s Avatar
M.J.L.
St. Jude Donor '10-'11
Pull it open, gut it, lubricate it, and be done.
Old May 29, 2009 | 10:25 PM
Dolfan's Avatar
Dolfan
Well, I guess hitting it with some lube or the PB can't be too bad considering it's function in life. Never thought about gutting it, but I do have to pass emissions here in ATL.
Old May 30, 2009 | 10:40 AM
M.J.L.'s Avatar
M.J.L.
As long as the car is hot, it will pass emissions and a visual check. It only injects on start up to. After that, it's just a spinning pully. Make sure you tighten the bolts down good. Ask me how I know.
Old May 30, 2009 | 05:56 PM
mgbss's Avatar
mgbss
It is common for the rear bearing to be shot if not grease everything up knock out the fins and put it back together.
Old May 30, 2009 | 06:48 PM
Dolfan's Avatar
Dolfan
I guess I crack it open tonight or tomorrow. It is still frozen even with some PB Blaster in in it!
Old May 30, 2009 | 07:47 PM
M.J.L.'s Avatar
M.J.L.
I hate to be the bearer of bad news but I gutted my pump and I soaked it in WD-40. I had to take a hammer and chisel and open it that way. Took about 20 minutes. Smashed the fins out. Lubed it up REAL good, I used loc tite to put the bolts back together to make sure it wouldnt break open(I learned that after I tore up a 40 dollar belt). No problems and it still looks stock!
Old May 30, 2009 | 08:43 PM
Dolfan's Avatar
Dolfan
What's the process for gutting it? How did you get rid of the fins! I assume those are the two fins that go through the interior cylinder. What lube did you use.
I just broke it open and cleaned the back plate, then slapped some lithium grease into it. It spins OK, but not great, I worry that it might lock up and then of course eat or toss the belt.
Old May 30, 2009 | 08:53 PM
M.J.L.'s Avatar
M.J.L.
Lotssssss and I mean lots of WD-40. I went thru 4 large cans. Mine was making a aawful racket. Take a hammer and just smash em out. If it locks up on you, say goodbye to the belt and hell to 100 dollars instead of 50. I need a eliminator pully.
Old May 30, 2009 | 09:16 PM
Dolfan's Avatar
Dolfan
OK, I just painted it up to match the rest of the accessories but I think I better break it open and make sure it wants to play nice before saying it is done!
Old May 30, 2009 | 09:17 PM
M.J.L.'s Avatar
M.J.L.
Im nervous for you!
Old May 31, 2009 | 12:25 AM
Dolfan's Avatar
Dolfan
Yeah, I'll crack it open again and see what is up, or $50 for new one isn't the end of the world. Just hate to spend anything for this type of equipment.
Old Jun 7, 2009 | 04:22 PM
Dolfan's Avatar
Dolfan
OK, the pump is not moving that smooth so it is either gut it or replace. I don't want to invest $50 in a new one but I'm not really sure about the process to gut it. Can someone give me a good step by step pictures are even better.
Old Jun 7, 2009 | 04:29 PM
MK 82's Avatar
MK 82
WD-40 is designed to displace water. It is not a good lubricant.
Old Jun 7, 2009 | 04:36 PM
Dolfan's Avatar
Dolfan
I actually lubricated mine with lithium grease thinking that would work well on the bearing. But I think some how it gets hung up with the fins, although I don't really know how these work.
If I don't get any good idea in a day or so I'll have to replace.
To Air Pump problem
