Intake base and head mismatch
Old May 29, 2009 | 09:37 PM
Aardwolf's Avatar
Aardwolf
Default Intake base and head mismatch
I took a picture down the port of a big mouth base on a stock head.
I measured the head at 30 MM for port width, and the intake is also at 30 MM. So if you use a large base it port matches pretty well.
Old May 29, 2009 | 10:00 PM
383vett's Avatar
383vett
Looks like the top of the intake port on the head needs some dressing.
Old May 29, 2009 | 10:03 PM
Aardwolf's Avatar
Aardwolf
I'm putting in some ported heads. And a super ram!
Just about ready to lift off the drivers head, not bad for an evenings work.
I had the large base on the stock untouched heads for awhile and wondered what it looked like in there. Finally got a chance to take a pic!
Old May 29, 2009 | 11:29 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Originally Posted by Aardwolf
I took a picture down the port of a big mouth base on a stock head. I measured the head at 30 MM for port width, and the intake is also at 30 MM. So if you use a large base it port matches pretty well.
Hmmmmm....Your title says mismatch but you say it matches pretty well. Theoretically, it should match up since they're both 1204 ports.
I can't tell for sure in your pics....Are you showing that the ports didn't line up? I've read this as being a problem with some HSRs but hadn't heard it about TPI bases (large/not).
Old May 30, 2009 | 01:28 AM
383vett's Avatar
383vett
All right, another SuperRam believer!
Old May 30, 2009 | 10:29 AM
Aardwolf's Avatar
Aardwolf
When I installed it I didn't want to remove the heads and I expected a mismatch in the ports. But I just took the pic and measured, there isn't much if any mismatch.
Now I have heads ported to 1205 so I'll have to work on the base a little. Looks like it needs 2 MM extra width. My 1205 gasket set measures 32 MM.
I can't wait to try out this new setup! Ported 113's, 1.6 rockers, and a ported SR. I'm somewhat agonized over not changing the cam and being right there. Since I'm changing the timing chain, while I'm there changing the dampener. A cam change will put up a class with the Z06 though for my race classing.
Old Jun 12, 2009 | 09:43 PM
pologreen1's Avatar
pologreen1
awesome to see you are making progress, lets have an update please.
Old Jun 13, 2009 | 11:59 AM
Aardwolf's Avatar
Aardwolf
I posted more pix in the dampener thread I started.
http://forums.corvetteforum.com/c4-t...dampeners.html
To Intake base and head mismatch
