play in rear susp?
Old Jun 1, 2009 | 07:02 PM
kbak1's Avatar
kbak1
6th Gear
Default play in rear susp?
was checking rear end for possible bearing play there is no play in wheel hub but could lift hole assy up on both sides felt same as it does when you have bad ball-joints on front. is this common could not see anything that seemed loose.any help would be great
