Help me with some cam specs please
650 cfm carb
edelbrock aluminum heads, 10.5 to 1, 64 cc
TPI headers and magnaflow exhaust
Current cam is a Comp Cams roller, 224, 224, 110...it's a cam with a ton of top end, but it is sluggish around town and hard to start and keep a good idle. Horrible on gas...
Would like to swap cams only...can you give me some input?
Would like....an easy starting car that idles fairly smooth but still sounds like it has something other than stock cam. More importantly, I want a ton of low end...you know...that torquey off the light kind of power feeling.
Suggestions for specs?
Thanks.
