DRM trailing & camber rod brackets
Old Jun 2, 2009 | 01:35 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Default DRM trailing & camber rod brackets
Originally Posted by Randy@DRM
I have now found a shop that meets all of our high standards. The best part about it, we can keep the pricing the same as before! They will have them done and Black zinc plated in 4-5 weeks. Just in time for spring
What I need to know is how many people would order them in the next 6 monthes and what year is the car. Both camber and trailing arm brackets for 200 dollars, or 109 a peice.
Let me know before Monday when I put in the order, I just have no idea how many to order on the first batch.
DRM Trailing Arm Brackets
for C4 Corvettes
Precise weight transfer is critical for optimum acceleration, braking and cornering. DRM brackets alter the trailing arm mounting point locations taking some of the anti-squat out of the Corvette. The additional weight transfer results in improved traction. Improvement will be realized at autocross, road course and drag racing events.
DRM Rear Camber Brackets
for C4 Corvettes
The amount of tire in contact with the road determines grip. DRM brackets relocate the camber arms mounting point locations reducing camber change throughout the full range of suspension travel. The added traction these brackets provide will be realized at autocross, road course and drag racing events.
He'll run another batch if we can get enough people interested
http://forums.corvetteforum.com/auto...post1570302208
I did a run of about 40 sets of each item. Sold them all besides some 84-87 camber rod brackets, which weren't that hot of a item. I just made the phone to see if the shop that builds these is very busy or not. Lunch time, so I'm sure we will hear something soon.
How many people would be interested??? I hate parts sitting on the shelves not moving
Randy
Old Jun 2, 2009 | 01:56 PM
87L98Z52's Avatar
87L98Z52
Im in!!!!!!!!!
Old Jun 2, 2009 | 02:00 PM
ddahlgren's Avatar
ddahlgren
Originally Posted by 87L98Z52
Im in!!!!!!!!!
Same here.. just let me know if it is going to happen fair enough?
Dave
Old Jun 2, 2009 | 02:24 PM
rfn026's Avatar
rfn026
Here's a whole article on C4 rear suspensions. I've got measurements and pictures of the part that Randy is talking about.
Richard Newton
Old Jun 2, 2009 | 02:38 PM
MyFatNutz's Avatar
MyFatNutz
DRM Trailing Arm Brackets 1995
Old Jun 2, 2009 | 02:57 PM
BrianCunningham
Richard Newton
That's but he may not get enough customers to make them if you're giving out his dimensions.
Old Jun 2, 2009 | 03:01 PM
Mojave's Avatar
Mojave
Go post in the other thread so he'll make another batch.
Old Jun 2, 2009 | 03:03 PM
383vett's Avatar
383vett
I used the camber brackets for years when I was drag racing with the irs. They really helped keep the tires square to the ground and decreased 60' times.
Old Jun 3, 2009 | 07:40 AM
Snakecharmer383's Avatar
Snakecharmer383
I got both of these and as soon as I get a clutch they are going in. I waited a long time to get these and hope they help.
Old Jun 3, 2009 | 07:50 AM
rickneworleansla's Avatar
rickneworleansla
Anyone else notice this? How much did 60' drop?
Old Jun 3, 2009 | 08:31 PM
aboatguy's Avatar
aboatguy
I'd love more traction!!
Old Jun 7, 2009 | 07:12 PM
aboatguy's Avatar
aboatguy
Are they going to be made??? If so pricing??
Old Jun 7, 2009 | 08:45 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
One thing no one has said yet is, do we need to re think our rear suspension alignment, as these brackets make the rear suspension more efficient/effective.
ps, I like mine, they are pretty. Seriously my car does handle a little better by my SOTP as I have a special road I abuse, and I am able to go in and out faster without my suspension getting pissed.
Old Jun 14, 2009 | 12:46 PM
BrianCunningham
Looks like it's happening.
I would would you could run a less aggressive alignment, but that's really a question for DRM
Old Jun 14, 2009 | 02:48 PM
tequilaboy's Avatar
tequilaboy
Alignment with the DRM brackets raises a good question.
I'm seeing alot of outside tire wear with approx. 0.7 degrees of negative camber on the rear. I'm thinking I need even more negative camber, or a stiffer rear bar (22 mm rear bar presently).
Old Jun 14, 2009 | 03:50 PM
steve40th's Avatar
steve40th
I am running -1.2 rear with 315's, but I only have about a 1000 miles of abuse on them, and no strange tire wear, yet.
Old Jun 14, 2009 | 11:41 PM
Snakecharmer383
Intresting, I didn't even think about getting the rear aligned after the install of these....another expense I guess.
Old Aug 25, 2009 | 09:08 PM
BrianCunningham
Mine were here when I got home
Nice looking pieces!
Old Aug 25, 2009 | 09:28 PM
aboatguy's Avatar
aboatguy
Mine arrived yesterday.
I'm going to use the street alignment specs posted by Randy in the other thread.
http://forums.corvetteforum.com/c4-p...-brackets.html
To DRM trailing & camber rod brackets
