{SCORP} Centerbolt Wire Loom Kit
Old Feb 7, 2002 | 06:04 PM
FlyboyZR1's Avatar
FlyboyZR1
Default {SCORP} Centerbolt Wire Loom Kit
Scorp,
I checked with Summit on the centerbolt valve cover wireloom kit you have ($40 :eek:) , and it says it's for 1987-2001 Chevy engines. What happened to '86? Are plug wires on the '86 a different size than '87+? I just want some damn looms that'll work if the MSDs dont fit!!
Old Feb 7, 2002 | 06:09 PM
scorp508's Avatar
scorp508
Default Re: {SCORP} Centerbolt Wire Loom Kit (FlyboyZR1)
Early '86 had perimeter valve cover bolts on the iron heads. The late '86 vettes had the aluminum heads w/centerbolts. I you have centerbolts, then you can use the same kit. :) yeah it is pretty expensive for what you (don't) get.
