HVAC blower relay location
Old Jun 3, 2009 | 01:14 PM
95davev's Avatar
95davev
Default HVAC blower relay location
About every 4th or 5th time I start my '95 the HVAC blower does not come on. It has the electronic system. The buttons all work fine and the AC compressor is turning on. If I hit a pothole/bump with my right front tire then the blower comes on. I'm pretty convinced I have a relay that is hanging up. Once it comes on it works fine and never quits until I shut it down.
Anyone familiar enough with the system to know where there is a relay for the blower located?
Old Jun 3, 2009 | 03:13 PM
SunCr's Avatar
SunCr
There isn't one. Electronic uses a Module that amplifies Low Voltage signals from the Processor (Programmer for your Year) to run the Blower. It's bolted to the top of the Evaporator Case. Brown or Dark Tan is usually the input. Purple is the out. Red is power. Check the connector. Check Connector at the Blower Motor. If the Compressor is cutting out along with the Blower, check Connector at the Low Pressure Switch.
Old Jun 3, 2009 | 04:14 PM
95davev's Avatar
95davev
Thanks. I found the module. Since it appears to be solid state and not a mechanical relay I can't see how hitting a bump would make it start working. I just checked the connectors to it and they look to be in very good/clean condition. I'll check the connector to the blower. Compressor is not cutting out...only the blower.
Old Jun 3, 2009 | 07:48 PM
MikeC4's Avatar
MikeC4
The next time the blower motor does not come on, open the hood and bang lightly on the motor with a rubber mallet or something. Could be the motor itself is going kaput.
To HVAC blower relay location
