Y-pipe removal on '88 conv.
Old Jun 4, 2009 | 11:02 AM
radstringz's Avatar
radstringz
Default Y-pipe removal on '88 conv.
I'm getting ready to drop the front y-pipe and cat on my '88 vert. But it looks like the tight clearances may require the X-brace to be removed. Has anyone done this before? Any frame alignment issues?
TIA,
jr
Old Jun 4, 2009 | 11:45 AM
89onlyZ51's Avatar
89onlyZ51
Getting ready to do this myself.
Old Jun 5, 2009 | 06:28 AM
radstringz's Avatar
radstringz
Ok, the X-brace must be removed. A pair of frame reinforcements in the front need to be removed to reach the manifold studs.
As a shining example of Murphy's Law, one of the studs sheared off.Now the manifold itself needs to come off I'm thinking about replacing all the studs while it's down, even though it's unlikely I'll ever have the exhaust off again. There's just something half-azzed about putting it back together with rusty, scaly, nasty hardware.
To make matters worse, the pre-cats were fine, and the irritating rattle was only the heat shield on the main cat.
No work on it today - it's raining again...
jr
Old Jun 5, 2009 | 09:09 AM
lostnfoundC4's Avatar
lostnfoundC4
I feel your pain as I recently snapped one on each side. I tried, Freeze Off, Break Away, and PB Blaster. After breaking the first one I soaked a nut and stud in a cap full of PB Blaster for a week before I broke that one!
Luckily my neighbor has a lift and oxy. We had to remove the left manifold and with a lot of heat, got the stud on the right side out with an extractor without removing it.
He's a hemi guy and said Chrysler & Ford studs are much larger.
I told him "don't tell my wife, she thinks Chevy studs are!"
Good luck!
Old Jun 5, 2009 | 09:56 AM
radstringz's Avatar
radstringz
Old Jun 5, 2009 | 09:05 PM
86C4CONVERTIBLE4+3's Avatar
86C4CONVERTIBLE4+3
Piece of cake. Just did mine last weekend. Every nut and bolt came off easily. Do yourself a favor and change the fuel filter while you have the x - brace off too. Gutted all 3 of my cats and a new filter and it feels like a new car. Biggest pain in the *** is finding places to jack from, and places to put jackstands. Get it high in the air and it's a piece of cake to work on.
Old Jun 6, 2009 | 06:53 AM
86PACER's Avatar
86PACER
You don't need to even touch the two front diagonal frame braces to drop the front Y. I have found it unnecessary. Just the main X-Brace if convertible. Plenty of room with the front raised, extensions and deep socket from below to get to the 3 manifold studs. I've done this about half a dozen times.
Luckily, the broken studs unscrew from the manifold. I picked up a new hardened set of 6 from my local muffler shop. Some anti-seize on the threads and they went on like butter.
Old Jun 6, 2009 | 10:07 AM
radstringz's Avatar
radstringz
That's the plan!
-jr
Old Jun 6, 2009 | 03:20 PM
j-wireman's Avatar
j-wireman
What did you use and how long did you let it soak in?
And, thanks for the tip on the fuel filter. Excellent information.
Mike
'90 'vert
Remembering our vets who sacrificed so much on this day in 1944
Old Jun 10, 2009 | 06:09 PM
radstringz's Avatar
radstringz
Got my manifolds back from the machine shop today. Unfortunately, the studs on mine didn't come out easily! Soaking in weasel p*ss was futile! They were rusted and seized and it took a torch to get them out. Now the new studs have a really loose fit. Is this normal? Anyway, they're long enough that I can back up the flange threads with a nut if need be.
All this started because of a small exhaust leak at the flange, and an annoying rattle that I thought might be the pre-cat innards breaking up. Anyway, it'll go back together in the AM, minus the rattly heat shield on the main cat. It's gutted, so heat shouldn't be a problem. An oil and filter change, and then on to fixing other problems. Did I mention that she sat for 2 years? I'm expecting to have to replace the injectors as well.
jr
To Y-pipe removal on '88 conv.
