Weird solution for brake failure.......
He would push the brake pedal and would go all the way down. Something like a Master cylinder failure.
For some unknown reason they scanned the 91 Vette ( automatic) and found problems with TPS. Vette had high idle RPM's.
Weird thing is that mechanics said that the braking problem had to do with a defective TPS.
So they changed the part and no more problems!!
I can not understand what TPS ( Throttle positioning sensor ) has to do with the brake system. Is there any relation or is it coincidence??
Did you hear something like this before? I had braking problems and replaced master cylinder, SS Brake lines, Super ATE Blue racing brake fluid, speedbleeders, bleeding a lot, changing pads, etc .
That was the way I solved the problem, but this seems interesting.
I am not sure if it had ABS and will check it.
