Fuel Injection Cleaning
Old Jun 5, 2009 | 06:29 PM
BlackRoseNY92's Avatar
BlackRoseNY92
Default Fuel Injection Cleaning
I was told that back firing on my c4 is being caused by a clogged fuel injector. Would cleaning the fuel injectors by a professional service take care of this problem.
Dan
Old Jun 5, 2009 | 06:43 PM
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
You can try a pour-in solution like SeaFoam, or the OTC cleaner, but most likely you've got a dead player.
Get in touch with Jon at FIC (a forum sponsor here), he'll steer ya straight!
Old Jun 5, 2009 | 08:58 PM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
GM shops uses a cleaner that is attached to the fuel rail.
Old Jun 5, 2009 | 09:21 PM
BlackRoseNY92
Actually Jon is the person who told me about the injectors. First testing Ohms and then change the injectors. Thought maybe cleaning may save me a couple of bucks.
Old Jun 5, 2009 | 09:46 PM
FICINJECTORS's Avatar
FICINJECTORS
Supporting Vendor
gm has not condoned the cleaning of multecs for years.. the first service bulitin came out in 94, here is the latest by AC Delco to all Jobbers and dealers. Read the section concerning pre 94 multecs. I would think that GM knows something about the problem. If a dealer is cleaning pre 94 multecs they are actually doing more harm than good
http://acdelcotechconnect.com/pdf/tsb/tsb_05D-105.pdf
Old Jun 6, 2009 | 08:17 PM
BlackRoseNY92
Default Fuel Injectors
Ok I read the GM bulliten. I'm won't be doing the work myself bringing to a mechanic. Is there a way to test the Injectors to find out which is clogged. Do I need to change all the Injectors or can you just replace clogged ones.
Dan
Old Jun 6, 2009 | 09:52 PM
FICINJECTORS
Supporting Vendor
Dan
i would not recommend doing anything to try to fix multecs. They are going to fail eventually, why not spend 169.00 and get a set of Bosch injectors that won't fail. To check the injectors you have to remove everything as if you were going to change them, so, you might as well change them
To Fuel Injection Cleaning
