Anti-Loc Light On
If you are using a multi-meter and getting all the right voltage feeds and continuity checks as outlined in the Shop Manual wiring diagram, all 3 relays test good, and fuses are fine, then you must have a bad ABS pump (motor) since you are not hearing it prime up when you start the car and reach 4 MPH.
At some time before my ownership, my ABS compartment had been flooded with water up to the top. Everything was trashed. I scored an almost new ABS pump and computer with relays and wiring harness on ebay. With this and fixing a cut main voltage feed under the car (thick red wire coming from the junction block near battery) my ABS light went out, and my ABS pump now comes to life with each self test upon start up at 4 MPH.
So crack that shop manual back open again and bust out the multi-meter. Make certain that all 3 ABS relays are good (voltage and terminal continuity checks), and all the right wires have the right voltages at the right times all the way from the main feed fuses (Brake, Guages, Stop/Haz and INJ 1 fuses). If all this passes then it's has to be a ABS dead pump since you already swapped the ABS computer for another. The shop manual has a voltage, resistance, and continuity test chart that you can use with a multi meter to check each of the 3 ABS relays and all of the wiring to and from. It even has continuity checks for for the abs pump motor itself at the relay terminal points on top. This tests the internal windings of pump motor itself. A failed test here will tell you right off the bat that the pump motor has an internal break.
Everything you need to diagnose this thing is right there the book with the troubleshooting tables and ABS wiring diagram. And you don't really that special ABS tester that almost few GM dealer even carry anymore either. It's all about process of elimination. It's almost as important to know what it isn't than what it is, so you aren't just throwing parts at the problem guessing. If every wire, voltage feed, and relay check out with your multi-meter, then the only possibility left is the ABS pump itself.
Pump Motor Relay: Bosch# 0 332 002
Solenoid Relay Bosch# 0 332 205 003
Module Relay Bosch# 0 332 512 007
