Meziere Q
Old Jun 6, 2009 | 11:14 AM
ChrisWhewell's Avatar
ChrisWhewell
Default Meziere Q
I'm going electric.
But I wonder if its ok , after swapping the electric pump for the old mechanical one, to just leave that shaft spinning that used to drive the old water pump, with no load on it ?
Old Jun 6, 2009 | 11:54 AM
1SL0WC4's Avatar
1SL0WC4
i had no issues
Old Jun 6, 2009 | 01:55 PM
STL94LT1's Avatar
STL94LT1
Some do, some don't, I didn't. It leaves the possibility for an oil leak without the shaft supported by the water pump.
Old Jun 6, 2009 | 03:56 PM
rickneworleansla's Avatar
rickneworleansla
I left it on for several months with no problems. I did forget to remove the coupler though. When I finally got to swapping the cam I removed it and got someone to weld the hole closed in the timing cover.
Misc. Pics...
Old Jun 6, 2009 | 04:51 PM
aboatguy's Avatar
aboatguy
Used a freeze plug IOT seal mine, no leaks and its been years
Rick how does your engine get so nasty???
Mike
Old Jun 6, 2009 | 08:21 PM
rickneworleansla
Mike
I have no idea. That was before the new cam, opti, chain, valve train, oil pan gasket, etc.. I cleaned it a good bit and it has stayed clean now. I guess whatever was leaking is fixed. It looked like it was coming from the TB or manifold. Somewhere in the front.
To Meziere Q
