94 radio problem
Old Jun 7, 2009 | 03:54 AM
llesg's Avatar
llesg
Default 94 radio problem
My radio stopped working at 10:26 exactly the other night. I know because it is still displaying it. Also in the lower right is an SVC or SCV,cant remember, but no worky!! Any clues???
Old Jun 7, 2009 | 12:51 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
Check your fuses and SCV is Speed compensated volume and is ok.
Preety sure you blew a fuse.
Old Jun 8, 2009 | 03:52 AM
llesg's Avatar
llesg
Checked fuses and they are fine(2 of them)
After I put the fuses back, the clock reset to 1:00
Old Jun 8, 2009 | 05:58 PM
RLG's Avatar
RLG
What is the current status of the radio?
Old Jun 10, 2009 | 02:55 AM
llesg's Avatar
llesg
When I turn it on nothing happens. Only the CD eject botton makes noise when pushed ,otherwise nothing
Old Jun 10, 2009 | 05:56 PM
RLG's Avatar
RLG
is it the Bose gold?
If it is there are several parts that could be suspect. The control head, the radio rec., or all 4 amps went out at once which would probably not be the case.
disconnect the battery , you might get lucky and it will reset.
Old Jul 25, 2010 | 11:41 AM
SuperCharged78Vette's Avatar
SuperCharged78Vette
Cruising
mine just started doing this too? does your antenna go up? mine doesnt.
To 94 radio problem
