Bracket Racers.....
Old Feb 8, 2002 | 11:07 AM
REDGAR's Avatar
REDGAR
Cruise-In II & IV Veteran
CI VI Drag Champ!
Default Bracket Racers.....
I know to be consitent you want the car to be the same every time and that includes weight.
Do you try to gauge (no pun intended) the amount of fuel in the car or do you eliminate that variable by racing with a full tank EVERY time?
Old Feb 8, 2002 | 11:49 AM
Vic'89's Avatar
Vic'89
Default Re: Bracket Racers..... (REDGAR)
Edger
What I do is fill up before I leave for the track.
The track is 70 miles away. I burn about 3 gallons.
This way I have the same amount of fuel in the tank every time.
But, the 2 or 3 time shots should give you the dial in number for the day.
Also, since the weather is changing every week, I don't see how you could base you dial in on last week's numbers ?
Vic
Old Feb 8, 2002 | 12:55 PM
REDGAR's Avatar
REDGAR
CI VI Drag Champ!
Default Re: Bracket Racers..... (Vic'89)
So you are basically a full tank racer Vic.
I think I am switching to full tank racer too
[Modified by REDGAR, 11:55 AM 2/8/2002]
Old Feb 8, 2002 | 12:59 PM
scorp508's Avatar
scorp508
Thankfully my range and average MPG gauges are very very good indicators of how much gas exactly is left in the tank. I typically try to weigh in on the scale around 3350 give or take 15 pounds when I am at the track.
Normally I try to gauge it so that I get to the track with 1/3-1/2 tank of gas. If the weight is fine, then I leave the car alone. If I am too heavy, I will take the spare tire out to save 30 pounds. If 30 pounds is too much, I'll toss some of my tools back in the hatch. :)
Old Feb 8, 2002 | 01:01 PM
ConeKLR's Avatar
ConeKLR
Cruise-In II Veteran
Default Re: (scorp508)
I autox with the same amount of fuel each time.
Old Feb 8, 2002 | 01:05 PM
ralph's Avatar
ralph
i've seen some of the Stockers measuretheir fuel after each run. They run with the tank pretty low for max performance, and add whatever they burned on the previous run. easy with the vette. my buddy would use a ruler.
I usually do what Vic does as far as filling the tank, however in the good air i try to keep it just above 1/2 tank for best performance, but i gotta be careful cause if it drops below 1/2 tnk, it will suck air at launch.
REDGAR's Avatar
REDGAR
CI VI Drag Champ!
Default Re: (ConeKLR)
I'm with you on the same amount of fuel but how certain are you that it is accurate? Is the gauge accurate? If we say within 1/8th of a tank give or take, that is like a 1/4 tank variable.
[Modified by REDGAR, 3:13 PM 2/8/2002]
Old Feb 8, 2002 | 04:09 PM
Tony.96LT4's Avatar
Tony.96LT4
Edgar, I try to race with the same amout of fuel in the tank. Usually 3/4 when I get to the track. 1 less thing to factor in.
Old Feb 8, 2002 | 04:11 PM
mackeyred96's Avatar
mackeyred96
From: Former NCM Drag Racing coordinator, National director Corvette Challenge Spring Hill, Tennessee: Whiting, New Jersey
Cruise-In VI Veteran
Cruise-In VII Veteran
I want to hear Panuzzo's reply on this one :crazy: :crazy: :crazy: :crazy: :crazy: :crazy: :crazy: :crazy: :crazy: :crazy: :crazy: :crazy: :crazy: :crazy: :crazy: :crazy: :crazy: :crazy:
Old Feb 8, 2002 | 04:13 PM
REDGAR's Avatar
REDGAR
CI VI Drag Champ!
I understand that but I am thinking like the car could have different characteristics is you start the day with 1/2 tank getting down ot 1/8th tank vs. starting with a Full tank and getting to 1/2 tank.
I guess I am splitting hairs
Vic
Old Feb 8, 2002 | 04:25 PM
mackeyred96
Edgar, you must adjust for fuel load just as you would weather or track conditions but you should never count on fuel weight for traction.
Old Feb 8, 2002 | 07:11 PM
Joel Platts's Avatar
Joel Platts
Default Re: Bracket Racers..... (mackeyred96)
Last season I started off running on a half tank, by the end of the season I was runnig a full tank of gas because the car ran more consistant. Take it for what its worth, my car is easier to predict a full tank.
Old Feb 8, 2002 | 09:22 PM
jpee's Avatar
jpee
We all KNOW weight will slow you down...Gas weighs app 6-7 lb per gal so 20 gal = app120lb... and a rule of thumb is for every 100 lb you remove you pick up a sec.. so I run it TOTALLY EMPTY.. :)
Old Feb 8, 2002 | 09:34 PM
scorp508's Avatar
scorp508
Default Re: Bracket Racers..... (Red96Coupe)
Just hook a hose up to your rear and go huh? :D
Old Feb 8, 2002 | 10:13 PM
REDGAR's Avatar
REDGAR
CI VI Drag Champ!
John that is an interesting statement on not relying on fuel for traction. You read into on of my concerns.
Can you elaborate on why we should not rely on fuel for traction? (presuming we always run full tank of gas)
My real concern is am I hurting anything other than my ET running on a full tank of gas
Old Feb 8, 2002 | 11:36 PM
Vic'89's Avatar
Vic'89
I am interested in that also Edger.
It would seem that the extra 100 lbs would help traction.
Vic
Old Feb 9, 2002 | 12:18 AM
jpee's Avatar
jpee
I guess this is splitting hairs also, but if you take two cars say two (C4's) & both had app the same HP (example 500) but one was 3400 lb, & the other was 2800lb... we all know the lighter one will be faster, BUT the lighter one will break less parts.. in general, or in the long haul say in 2 years of every week racing the heavier car will usually break more parts, only because of the weight...
Here is an example, when Bill Casey was running his car as a C/A and wanted to run D/A he had to either get a smaller motor, or ADD weight, so he added weight...the following year, he broke more parts than ever..
He finally made the car lighter, sold the big motor, & ran a 290 ci small motor to run D/A & his parts breakage went way down..
Agreed our cars are not running on the "edge" like a NHRA Comp car, but it IS the same principle.. If I can run at 3400 as opposed to 3500 why would I want to run at the heaver weight ? No advantage that I can see..?
However I'm always ready & willing to listen to other opinions, & if I agree I'd add weight if it would help me..
To Bracket Racers.....
Old Feb 9, 2002 | 01:12 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Since I started with keeping 1/2 tank or more, I don't bog off the line anymore and my 60' has improved.
Old Feb 9, 2002 | 04:18 AM
65Z01's Avatar
65Z01
I run with 1/4-1/3 tank and no spare/jack for a little better performance at the top end. I don't need to rely on the gauge accuracy only that it be consistent from day to day.
I agree with JP on the extra weight issue. More static weight means more inertia to be overcome on launch, Newton's Law. Less weight (mass) means less stress on the drive train.
Traction should be dealt with by adjusting driving technique, rubber and/or suspension as required.
So Edgar, you should run just enough fuel so as not to lean out before the end of the events and try to be consistent as possible. A few gallons is worth 10-15lbs and you can plug that variable into the equations to see how much that impacts your ET.
That's my story and I'm sticking with it.:)
[Modified by 65Z01, 2:25 AM 2/9/2002]
Old Feb 9, 2002 | 12:59 PM
Beach Bum's Avatar
Beach Bum
Default Re: Bracket Racers..... (65Z01)
Good question Redgar,
As Ralph said, with an early C4 and if you run a 1.70 60 ft you have to run at least 1/4 tank of gas.... if you have the ability to run 1.6x 60 fts or quicker a 1/2 tank is advised other wise the pump will pick-up air for a split second that will hit your injectors 10-20 feet out.... not good for your 60 ft time as you could have guessed. Thus I typically race with 3/4 tank of gas. I haven't heard of 88 and up C4's having this problem.
As Vic said, as far as consistency, at our level the weather on that day will play a bigger role than a few gallons of gas.... but I can see the Pro's taking this seriously, they are not only trying to dial in their consistency motor consistecny, but they are also dialing in their weather stations, which means they have to pay attention to all variables including the weight of fuel and the effect it has on their suspension dynamics.
Beach Bum
