what does LT1 mean?
Old Jun 7, 2009 | 07:48 PM
new 90 vette's Avatar
new 90 vette
1st Gear
Default what does LT1 mean?
My new(for me) 90 convertible has "Lingenfelter Performance Engineering" across the windshield and LT1 with a Corvette symbol on the rear. What does LT1 mean and does "Lingenfelter" have anything to do with it.
Tnanks,
Earl
Old Jun 7, 2009 | 08:01 PM
slickfx3's Avatar
slickfx3
Tnanks,
Earl
no, just a new induction hardware introduced by chevy after the tpi cars, I think a 90 is still a tpi car.
Old Jun 7, 2009 | 08:10 PM
Aurora40's Avatar
Aurora40
LT1 was the engine designation for all Corvette V8's from 1992 through 1995, and on all automatic 1996 Corvettes. Your 1990 came with an L98, not an LT1. It's possible someone swapped in a take out or crate LT1, but it's more likely it either isn't an LT1 at all, or it simply has a similar intake manifold.
Can you take a picture of the engine?
Lingenfelter Performance Engineering is a well-known modifier of Corvettes and other cars. It is possible they did work on the car, but it's also possible the previous owner was just a poser.
Old Jun 7, 2009 | 08:30 PM
TorchRedlt4man's Avatar
TorchRedlt4man
From: Chicago Executive Airport, formerly known as Palwaukee
No-IL Events Coordinator
St. Jude Donor '12-'13-'14-'15-'16-'17
LT-5 was the designation for the 32-valve dual overhead cam V-8 which was installed in all ZR-1s built from 1990 to 1995.
This is also a V-8. Designed by Lotus Engineering in Great Britain and built and assembled by Mercury Marine in Stillwater, Oklahoma.
The LT-5 engine was the only factory produced V-8 engine (installed in ZR-1s built in Bowling Green, Kentucky) sold by General Motors which was not built by General Motors.
Just wanted to make sure our questioner was not confused by our answers.
rodj's Avatar
rodj
Originally Posted by slickfx3
no, just a new induction hardware introduced by chevy after the tpi cars.
LT1 was last development of the convenional SBC format.
Same block dimensions , many internal parts interchange with earlier engines but redesigned cyl heads , reverse flow cooling ,a short runner intake and a front mounted dist
Old Jun 7, 2009 | 08:34 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
isn't it an option code?
LT1-LT5-LT4-L83-L98-FX3-F45-FE1-Z51-G92-
LS1-2-3-6-7-9
Old Jun 7, 2009 | 08:37 PM
SEVNT6's Avatar
SEVNT6
LT1 means lots of money when it comes to a C3...........
Old Jun 7, 2009 | 08:39 PM
TorchRedlt4man
It is an RPO code.
What exactly does RPO stand for?
Regular Production Option? Just my guess.
Old Jun 7, 2009 | 08:46 PM
No Go's Avatar
No Go
"LT1 means lots of money when it comes to a C3"
You mean LT-1 means lots of money for a C3...
Old Jun 7, 2009 | 09:04 PM
pologreen1's Avatar
pologreen1
LT1 is an engine code, because corvettes and cars in the 70's had them, the difference for a c4 corvette is the intake that comes on it, compared to the L98 model which has a long tube runner intake, both are tune ports though.
corvettes through out the years or cars period have letter and number engine codes, you just see it used more here, to distinguish years
Old Jun 7, 2009 | 09:12 PM
SEVNT6's Avatar
SEVNT6
Picky Picky...
You C4 guys don't miss a thing........
Old Jun 8, 2009 | 11:48 AM
josephf31's Avatar
josephf31
Default Yes
LS1-2-3-6-7-9
LT-1 is the engine code, not to be confused with small block 350 LT1 motor available around 1970 on the Corvette, Camaro, etc.
Old Jun 8, 2009 | 12:19 PM
PLRX's Avatar
PLRX
2017 C4 of Year
That's why they engrave numbers on the block and heads. Yes, there were lots of LT engines in the 90s (Vettes, Camaro, Caprice, Impala and maybe more) but a Corvette LT engine is not an Impala LT engine.
Example
All 1996 Corvettes blocks are 10125327
LT1 suffix: ZXA
LT4 suffix: ZXD
Heads:
10207643: 350 CI, 300 HP, AT (A4) (LT1)
12551561: 350 CI, 300 HP, LP (Late Production) (LT1)
10239902: 350 CI, 330 HP (LT4)
12555690: 350 CI, 330 HP, LP (Late Production) (LT4)
On 1984, 1986 there were 10 different suffixes, what the heck happened those years?
So, were the LT2 and LT3 prototypes that never went into production?
Old Jun 8, 2009 | 12:52 PM
MK 82's Avatar
MK 82
L98 to LT1 is more than induction hardware. 90 is an L98.
Old Jun 8, 2009 | 01:32 PM
ch@0s's Avatar
ch@0s
I thought it was just a cool sticker. I put a lt5 sticker hash marks and zr1 wheels on my l98 and its 200mph faster now
Old Jun 8, 2009 | 02:25 PM
65MalibuSS's Avatar
65MalibuSS
"The LT-1 was the ultimate 350 cu in (5.7 L) V8, becoming available in 1970. It used solid lifters, 11:1 compression, a high-performance camshaft, and a Holley four-barrel carburetor on a special aluminum intake to produce 370 hp (276 kW) and 380 lb·ft (515 N·m). It was available on the Corvette and Camaro Z28."
The "LT1" designation was later reused on a Generation II GM engine, the LT1.
The original LT-1 was considered the most powerful small block ever manufactured and was very similar to the 302 cubic inch Z28 engine which was made between 1967 and 1969.
Old Jun 8, 2009 | 03:34 PM
JAKE's Avatar
JAKE
Yep, it's a lot more than just the hypen that makes the difference between the two engines. Early LT RPO had a hypen and the newer ones don't.
Jake
West Point ROCKS!
To what does LT1 mean?
Old Jun 8, 2009 | 05:24 PM
cumbercr's Avatar
cumbercr
LT = Less Torque
Old Jun 8, 2009 | 06:08 PM
reoch999's Avatar
reoch999
Originally Posted by cumbercr
LT = Less Torque
Than???
Old Jun 8, 2009 | 06:41 PM
No Go's Avatar
No Go
The early LT-1 generation was the most powerful SBC...until the LT1 (Gen II) arrived.
This is true in HP and TQ...remember early was gross HP ratings (360/370) and the modern is a far more conservative number/calculation.
