high idle 1990
Old Jun 8, 2009 | 04:34 AM
jeffp1167's Avatar
jeffp1167
Default high idle 1990
Everytime I start this car it does the cold high idle and comes down yet never falls below 1100rpm.
however it almost sounds like the engine is idling at normal speeds (by ear) being it doesn't seem like it is at that rpm. Another thing weird the tach does, is when you mash the accelerator quikly it will peg the tack of the scale completely. Are there issues with the 90 tach and all of this is just a false reading on the tach? because at 1100 or so rpm on my trans ams engine it sounds like it's racing compared to how the vette sounds.
Old Jun 8, 2009 | 06:04 AM
EastCoastHD's Avatar
EastCoastHD
There are known issues with the tach on C4's. I believe the tach filter is the most common culprit. Do a search, plenty of info.
Old Jun 8, 2009 | 08:20 AM
jimmers's Avatar
jimmers
Sounds like the tach is bad. It's very common on the '90s. You can try removing, or buying a new tach filter to see if it helps. You will most likely need a new cluster or have to get yours rebuilt. An easier and cheaper way is to get a cluster out of a '91 or '92. They don't have any issues like the '90s did. Thats what I did with mine a few years ago and its been working great since!
Old Jun 8, 2009 | 05:56 PM
RLG's Avatar
RLG
mine is doing the same thing. There are some issues with the tach's.
I need to dig out my digital inductive Tach/dwell meter to see how far it is off.
Old Jun 8, 2009 | 06:07 PM
bill mcdonald's Avatar
bill mcdonald
Probably a bad tach filter.
I dont know of a replacement.
I put in an msd, cut the tach filter out and ran the "tach out" of the msd to the wire left over from the tach filter. no issues after doing this.
I dont know of you can just bypass the tach filter with teh same results.
Old Jun 8, 2009 | 06:26 PM
jeffp1167's Avatar
jeffp1167
Yeah I looked for on but only pre-90 is available. I'm curious why vettes have it. I have never seen one on a f-body so I'm wondering if it can be bypassed as well.
Old Jun 8, 2009 | 06:52 PM
jimmers's Avatar
jimmers
After I got a new cluster the tach was still a little jumpy around 3k rpm. I removed the tach filter and its been perfect ever since.
If you just remove the tach filter with the cluster you have now, chances are it won't fix a thing. I would buy a cluster from a 91-92 and just do a direct swap. Your problem will be gone for good. It's much cheaper then getting your cluster fixed.
Old Jun 8, 2009 | 06:54 PM
jeffp1167's Avatar
jeffp1167
feel like just getting out my corvette adjustment tool
Old Jun 9, 2009 | 11:22 AM
josephf31's Avatar
josephf31
Default Not really
The '91s are also known for being bad. Ask me how I know :-)
Old Jun 9, 2009 | 08:12 PM
jimmers's Avatar
jimmers
Ok then he should get one from a '92!
Old Jun 10, 2009 | 03:33 PM
bill mcdonald
how much is a cluster?
Old Jun 10, 2009 | 03:44 PM
Dads90's Avatar
Dads90
300 and up. They will probably want yours. Could be a week or two on the repair. I just bought a rebuilt replacement and now I have an extra one to send in with so there is no down time. Try this http://www.tabercorvetteparts.com/parts/clusters.html
To high idle 1990
