need help
Old Jun 8, 2009 | 02:31 PM
85 novice's Avatar
85 novice
2nd Gear
Default need help
I am in the process of swapping my original L98 & 4+3 out for an L98 w/ T700 auto. There is one bulkhead connector from the engine harness that connects to the firewall behind the battery that I cannot figure out how to disconnect. All was goine too smooth until I got there. Any help.
Old Jun 8, 2009 | 03:24 PM
383vett's Avatar
383vett
I did the same swap. Why do you need to disconnect the connector?
Old Jun 8, 2009 | 05:48 PM
85 novice's Avatar
85 novice
2nd Gear
The engine / tranny pkg I bought has the harness still completely attached. I thought it would be easier to to swap the unit with the harness intact.
To need help
