5.7ltr Crankshaft swaps
Old Jun 12, 2009 | 02:27 AM
Kromm's Avatar
Kromm
4th Gear
Default 5.7ltr Crankshaft swaps
Can I use the stock crankshaft from a 1985 L98 engine in a stock
1989 LT1 block ?
I know that the bolt pattern for the flywheel/ flexplate on the rear of the crankshafts are different ,anything else ?
Anyadvice or suggestions is appreciated.
Kromm
Old Jun 12, 2009 | 02:40 AM
rodj's Avatar
rodj
If you use this
http://www.superchevyperformance.com...p/10051118.htm
Old Jun 12, 2009 | 03:53 AM
lt4obsesses's Avatar
lt4obsesses
I didn't know there were any pre-1992 LT1 engines.
Old Jun 12, 2009 | 04:04 AM
rodj's Avatar
rodj
He is talking about a L98 1 pce RMS block ; same crank style as LT1
Old Jun 12, 2009 | 09:47 AM
Muffin's Avatar
Muffin
Originally Posted by rodj
Don't understand why anyone would want to do this. You can buy a replacement crank for about the same money.
Old Jun 12, 2009 | 10:05 AM
rodj's Avatar
rodj
but there are people out there that might have a expensive aftermarket crank that they want to run a OEM roller block.
To 5.7ltr Crankshaft swaps
