question
Old Jun 13, 2009 | 05:27 AM
mavidatt's Avatar
mavidatt
Default question
http://paceperformance.com/index.asp...&ProdID=198605
the zz4 engine with fast burn heads what would be the best intake to use with this if i was to go this route? Would a miniram be a good fit with this engine? I know the engine needs a better cam, but would it be better off with a miniram intake compared to like edelbrock hi flow runners and base manifold. has anybody used this engine with these heads and the stock zz4 cam that comes with it, and what intake did you use?
Old Jun 13, 2009 | 02:20 PM
ultraviolet70's Avatar
ultraviolet70
That's alot of $ for an engine you've got to tear down after purchase to change cam and rockers (which you have to buy as well) to get over 400hp. I would do some more research on building your own engine, you should be able to do it for less $ and make more power.
